Results 1 to 8 of 8
Thread: VIA M10000 and ram
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    VIA M10000 and ram
    Will this ram, http://www.pricegrabber.com/search_g...asterid=580921
    work with the VIA m10000. Is it the best choice, can I use higer bandwidth?...
    thanks
    My motherboard stopped working today, gots to buy a new one
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    yes it will work. why no going with kingston?? (+- same price)
    http://www.pricegrabber.com/search_g...=memory+pc2700
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Feb 2005
    S Ohio
    isn't that 333mhz, which is more than the m10000 can handle?
    My NEW carPC
    Constant Bitrate NeckPayne's Avatar
    Jul 2005
    Detroit, MI
    Good catch....I think you're right. The Epia-M is rated for 266.
    Here's a link to Kingston's memory configurator. I always buy Kingston, usually just as cheap and reliable...
    EDIT: Before someone else spanks me. DDR (as I just read) is backward compatible, so you should be able to use PC2700 in a PC2100 slot. If you're going to be buying it and not using RAM you had lying around, you'd want to buy for what you need, it's probably cheaper (not always though) to buy the inferior speed RAM if its all you'll get out of it.
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    Kingston is your friend
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    Quote Originally Posted by Moneyfink
    that is not an issue. generally, memory that can run @ 333 MHz is more reliable running @ 266 Mhz. otherwise, there is no technical issue.
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    Quote Originally Posted by NeckPayne
    Right, when I bought RAM for my M10000, I ended up with PC2700 because it was cheaper (same Kingston product line).
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    I had a stick of 2700 samsung kicking about so I used it in my m10k - no problems
  1. New M10000 no post with any ram
    By TucsonPred in forum General Hardware Discussion
    Last Post: 04-20-2005, 03:51 PM
  2. FS: EPIA M10000 Brand NEW WITH 256 DELL RAM
    By livininspirit in forum Classified Archive
    Last Post: 03-29-2005, 12:59 PM
  3. #$%@! NO! HELP! M10000 freezes while checking RAM
    By wizardPC in forum General Hardware Discussion
    Last Post: 12-19-2004, 07:38 PM
  4. RAM for M10000 Nehemiah
    By Tred in forum Newbie
    Last Post: 10-11-2004, 07:08 PM
  5. Replies: 4
    Last Post: 07-06-2004, 10:52 PM
