Results 1 to 9 of 9
Thread: Can MediaEngine build a home medai centre ?
    Aug 2005
    Orange NSw Australia
    Red face Can MediaEngine build a home medai centre ?
    Hi, I am a newbie, and came across the media engine via a PC USEr Magazine.
    I have loaded it onto my PC and can see that it might make a good engine for a home media centre.
    I would like to setup a dedicated pc as my home media centre, so that i can
    1. Play Divx movies on -demand from a 200Gb Hard Disk ( I have 100+ movies accumulated, mostly divx)
    2. Play mp3's thru Stere system
    3. Connect the movies output to my TV and 5.1 Sound System
    4. Use Remote to browse and select items to play on the TV screen
    I will need a Basic PC , Win XP Pro, connect to other Pc's in network (to upload with new material)
    I have a Packard Bell PC Remote i was hoping to use
    I will want a Digital PC Card (What TV Cards are compatable ??)
    I will also need a video card that can supply Video Out (not TV composite, it is not good enough) - What is a compatible AGP card ??
    have a MIRO DC30 card, and was wondering if I can use this ??
    Am I barking up the wrong tree, or should I be looking at Windows Media Centre ??
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    [note to moderator's: this should probably be moved to "Media Engine" or at least "Software"]
    Any of these front ends should be able to handle this, but why? It is my impression that they are mostly aimed at using within a touch screen interface. Although, they are built around lower resolutions so that would help make things look nicer on a TV.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
    Constant Bitrate NeckPayne's Avatar
    Jul 2005
    Detroit, MI
    Yeah...but I can see the potential of this. I mean seriously, the remotes that you can buy for this kind of thing are over $250. Can you imagine hardwiring and recessing the touchscreen into a little desk or the arm of a nice recliner in your "home theater?"
    If you're going to go the PC MediaCenter route as opposed to the high end way, then why not. If you're going to be fancy, may as well work it to have two video outputs, one to the touchscreen and the other to your DLP/LCD projector with DVI input or something or other.
    Good luck!
    Constant Bitrate JPuma's Avatar
    Jul 2005
    NY
    Do a search for Media Portal. It is exactly what your looking for. Its even great in the car.
    sim
    sim is offline
    Low Bitrate sim's Avatar
    Jan 2005
    Gloucerstershire UK
    Also consider GBPVR
    PC Chips 1500,512mb ddr,no case yet, LinITX 7" touchscreen,300w inverter,RoadRunner FreeDrive,BU303 gps mouse.
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    ...or Meedio?
    Mar 2005
    Czech republic
    ..or GotAllMedia?
    Aug 2005
    Thanks Guys, I'll check out these other option. They might be better suited to
    a Home Media Centre than this media engine.
    i''l let you know whit I find out, especially re PC to TV output problems
    Nov 2003
    Northern Arizona
    Quote Originally Posted by chansen1953
    Well really this should only be affected by the hardware. As long as the UI works at whatever x 525/480-ish at 60Hz interlaced you're fine. (If you're using an HDTV monitor, you've got more options).
    BTW, if you really want HTPC info, try AVS Forum. I haven't hung out there in a while but when I built my setup it provided all the information I needed.
    My worklog.
  1. Beta: CCarProject
    By BenjaminS in forum MacCar
    Last Post: 09-27-2006, 12:25 AM
  2. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  3. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 12:00 AM
  4. Pro, Home, Media Centre, Tablet, 2000, 98SE?
    By Lum in forum WinNT Based
    Last Post: 03-16-2005, 10:59 PM
  5. MediaEngine Development Progress Update
    By CarComp in forum Media Engine
    Last Post: 01-07-2005, 12:53 PM
