Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Help putting together a system
    Aug 2005
    Hi!
    I´m a total newbie when it comes to car PC and electronics, so realy need some help.
    To start with, I got a Golf V. I´m gonna keep the original audiounit, and put the tft screen on top of the panel instead.
    I´m thinking of getting the following stuff:
    * 7-12" 16:9 touchscreen TFT with a power consumption on max 10W. Would realy appreciate some tippps here, max 400 euro.
    * Ampie Car Computer Case - Link.
    * VIA EPIA MS10000E, EDEN/1000Mhz, Fanless Mini-ITX, DDR266, VGA, CF-Reader, SCART. - Link. It´s fanless which I think would be nice, less noise and no dust can get stuck in the fan
    * TwinMOS DDR SO-DIMM PC2700 512 MB CL2,5 WLCSP chip, 200pins for notebooks - Link. The motherboard has 200pin -
    * M1-ATX 90 Watt - Smart Automotive Power Supply - Link. This should be enough, right? or should I go for the Opus 120W instead, and if so, why? -
    * Pioneer Slot Load DVD±R/+R DL/±RW Dual Drive 8X - Link.
    * Need a good GPS to, any tipps? max 100 euro.
    * 2.5" Hard Drive 40GB Samsung 5400rpm - Link I´m gonna have a bigger disc, external, also 2.5" via USB.
    * bluetooth USB adapter
    * WLAN USB adapter
    I don´t need a monster computer, I´m just gonna use it for DVD, GPS, MP3, Bluetooth. I want the power consumption to be as low as possible.
    Realy need some help. What would you change, and why?
    Edit: Forgot the harddrive and USB adapters.
    Aug 2005
    If I choose to go with a smal 7" touchscreen (max 8W). Is it possible for me to use the stuff above, and just connect it to the 12V connection in the car? Use a cig split, and put both computer and screen in the same 12V cig. connecter?
    Poet Laureate rustyboxx's Avatar
    Feb 2005
    The Côte d'Azur of England - Hot totty central
    Quote Originally Posted by ABC123
    Yeah, that's possible, not always the most practical or permanent solution but certainly possible.
    Only true postwhores remember everything they post
    REP CLUB IS DEAD
    LONG LIVE REP CLUB
    Aug 2005
    Thank you for the answare
    If it´s a OK solution I´m thinking of starting with it. And when I have the knowledge/time, I can wire it "directly" to the battery.
    What do I need to do this?
    I guess I connect the psu to the chassi, does the chassi come with a 12V cig cabel ? or which adapter/cabel do I need between the psu/chassi and 12V cig connection? Do I need any other cabel/adapter?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    you want to connect your carPC permanantly to the ciggy lighter. where is a head banging on wall smilie when i want one?
    I would never install a carPC permanantly off the ciggy lighter. For one i would not trust the dash wiring connections, the wire gauge and I especially would not trust one of those ciggy lighter connectors as they are crap.
    And also, your PSU will jsut come with wires or terminals - you would obviously have to connect a ciggy lighter plug up to the PSU. I would jsut get a cheap amp wiring kit and hook it up to your battery from the off.
    Feb 2005
    Allow me
    REP CLUB IS DEAD
    LONG LIVE REP CLUB
    Aug 2005
    Is it really such a problem, even with new cars? The connector even says "12V power connection", and are not made for cig lighter, even though you can use one.
    Guess I can check with my VW dealer what they say about the orgininal cabels.
    How mutch does my config actually require? amp, wire gauge etc?
    (I was hoping on being able to use the 12V cig connector, since I know nothing about wirering and stuff. But if it´s not possible, I guess I got no other choice then to wire it up to the bat.)
    Variable Bitrate HHdesign's Avatar
    Mar 2005
    Plano, TX
    Dont use the cig lighter. I wouldnt even do it on a 2005 or 2006 model, run a wire to the battery, you'll thank yourself later.
    Jeep Grand Cherokee Laredo
    Kenwood X790 x/ iP500 Ipod Interface
    Elemental Designs 13Kv.2 D2
    CDT ES-620 (omg yayay!!!1)
    NINe.2X, NINe.2
    Mar 2004
    Bristol
    those connectors really suck. trust me.
    Elsewhere
    Look, man.
    Is it possible to use your cigarette lighter (or auxilliary power port) to power this? Yes.
    It's also possible that the increased power draw will, at worst, cause a fire in your car. If you want to take that risk, than be my guest. I'll be sure to give every flaming VW I see on the road a hearty nelson in hopes that it's you.
    Consider yourself warned of the potential pitaflls.
    How about the Wiki?
  1. New EWF + MinLogon and CF instructions
    By SFiorito in forum WinNT Based
    Last Post: 03-12-2010, 02:39 PM
  2. quick system disconnect idea
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 05-14-2005, 11:35 AM
  3. FS: Carputer system w/o monitor
    By Toups in forum Classified Archive
    Last Post: 04-21-2004, 01:43 PM
  4. FS: Carputer system w/o monitor (Boots in 15 sec)
    Last Post: 04-01-2004, 12:01 PM
  5. linux system owners with web site please post
    By Jake in forum General MP3Car Discussion
    Last Post: 10-23-2002, 09:39 AM
