Results 1 to 2 of 2
Thread: Pyle problems
    Aug 2005
    salina, kansas
    Pyle problems
    Well just the other day I was removing a sub from its box and i touched the basket on a positive pole of a 6 by 9 and yes they were on. What did i do? The head unit is fine i replaced the rca cables and the subs and speakers are fine. So the amps are messed up correct or what? If they are what do i do?
    Aug 2005
    Near Buffalo, NY
    You should first check the amps fuses. Your amp kits fuse and any connections. Check with a multimeter if you are getting voltage and current at the back of the car and check if you get continuity threw the speakers. That might give you a better idea of the problem. beyond that idk man good luck.
  1. DWW-700M/MTS12000 Motorized In Dash LCD Problems
    By techy101 in forum LCD/Display
    Last Post: 06-29-2005, 07:12 PM
  2. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 04:04 PM
  3. opus problems
    By studmonk3y in forum Power Supplies
    Last Post: 03-29-2005, 04:09 PM
  4. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 03:37 PM
  5. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 01:55 PM
