Results 1 to 7 of 7
Thread: Which regulator??
    Constant Bitrate ironic's Avatar
    Aug 2005
    Gibraltar(UK)
    Which regulator??
    Hey guys! So im kind of reading a bit, started to get into it.
    Now, i do see by what some guys say that it's impreative to introduce a regulator so spikes dont damage equipment.
    Now, from what i gather there are different types of regulators.
    What type of regulator woudl be placed near the battery that would be connected to a 400w inverter?
    Is it DC-DC 12v or what?What wattage should i use?
    Thanks!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If you are using an inverter and want to protect your PC from voltage spikes, do what you do at home -use a surge protector.
    Most of the DC-DC regulators are only rated for 150 watts or so. If your PC uses more than that, you wouldn't be able to use one.
    I could be wrong on this, but I think the inverter may help take care of some of regulation issue. Spikey voltage may go into the inverter but it's job is to convert that to consistent AC. Naturally, higher quality regulators would tend to have the sophistication to do this better.
    Want to:
    Aug 2005
    Gibraltar(UK)
    My PSU is 300W, that means io cant use a regulator?What happens if the inverter i have does not have the regulator feature incorporated?what do i do in that case?
    Thanks!
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Quote Originally Posted by Bugbyte
    Quote Originally Posted by ironic
    Thanks!
    Did you not read first.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
    Aug 2005
    Gibraltar(UK)
    Use a surge protector?A normal domestic surge protector??LOL ok...sorry my mind just dindt pick it up, was probably thinkin on some toher electronic device that was needed.So, this surge protector would go between the pc and the inverter?
    However, if i use a shutdown controller, it will be at risk of spike if i place it bewteen the battery adn the inverter. What should i do now?put a fuse bewteen the battery and the shutdown controller?
    Thanks!
    Apr 2005
    Fresno, CA
    1.yes
    2.yes
    3.yes
    4.Anyone else on this question, The inverter should be able to handle voltage spikes. I mean it was designed for a car right?
    5.Always fuse your equipment.
    Personally....first off, the regulators are to regulate the voltage for a DC to DC PSU ( i.e. 12 volts ) Im sure the DC to AC inverter has some kinde of surge protection built in. Or at least fault protection and is probably fused somewhere inside it. So as i started to type. Peronally i dont think a surge protector is really necessary. Although extra precaution is good.
    So if anyone can give a good reason to use a surge protector between a DC to AC inverter and a PC chime in please! It's not like lightning is going to hit the power line on your car and go through the inverter and fry your pc. It will skip everything and fry your pc directly
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
    Apr 2005
    Fresno, CA
    Thanks!
    I didn't realize you said that. An inverter is a regulator. It inverts from DC to AC and then REGULATES the output to 110vac or 230vac for you europeans
  1. Replies: 17
    Last Post: 06-10-2008, 04:41 AM
  2. Voltage Regulator Constant Heat
    By phita23 in forum General Hardware Discussion
    Last Post: 02-21-2005, 12:18 AM
  3. 3A 12v regulator?
    By hcker2000 in forum Power Supplies
    Last Post: 10-15-2004, 01:46 PM
  4. need help for regulator /need fuse
    By kalito in forum General Hardware Discussion
    Last Post: 01-28-2004, 09:26 PM
  5. Idea for a cheap 12 voltage regulator perhaps...
    By adamis in forum General Hardware Discussion
    Last Post: 09-11-2003, 07:31 PM
