Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: SIRIUS vs Xm antennas... the same..?
  1. #11
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    I thought there was some diference in the voltages. Like a Sirius system is 6v, and XM is 12v. That might be why you are expereiencing drop out. But I don't have anything to back this up.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  2. #12
    Jan 2003
    Ruston, LA
    No, its the way the antennas are designed. (I looked it up)
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #13
    Oct 2004
    Washington
    sirius has 3 satelites in a higher orbit that beam the signals down at about 45* and 90* angles, while XM is in a lower orbit, has only 2 satelites and beams the signals down at a 30-45 degree angle...
    thats the difference in the antennas... they're designed to pick up thier respective signals from a specific anlge if i understood it correctly.
  4. #14
    Feb 2004
    PA, USA
    But what is the difference between the antennas? If they are designed to pick up at different angles, they would be required to be setup at that given angle. The mobile antennas would work equally as well for both systems, because they are moving.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  5. #15
    Variable Bitrate fromplanetbob's Avatar
    Jan 2005
    They are not really designed to pick up different angles of satellite signal. SIRIUS and XM Operate on different frequencies and while they are close enough together in the spectrum that you can use a SIRIUS or XM antenna for either service, the correct antenna for the radio will pick up better reception because it's tuned in. It's like those old tvs with the fine tuning adjustment.
    But yes, you can use the antennas from either service on either radio, just expect some degraded signal which means more drop outs.
  6. #16
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    planetbob is correct. I have a sirius antenna hooked up to my XM in the car, and it cuts out more often than the XM antenna did, but it works. So it 'works', just not as well.
  1. Sirius PCR ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 03-15-2005, 05:55 PM
  2. XM or SIRIUS??
    By elk29n in forum FrodoPlayer
    Last Post: 12-07-2004, 07:44 PM
  3. Sirius Tuner Like the XM Direct?
    By Geese in forum Car Audio
    Last Post: 12-07-2004, 01:46 AM
  4. Sirius vs. XM...? what up Gee?
    By mindscream in forum Car Audio
    Last Post: 10-24-2004, 04:31 PM
  5. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
