Results 1 to 3 of 3
Thread: How to connect M1-ATX to car battery?
    Sep 2005
    Hi everyone. Sorry if this is a repeat, I couldn't find an answer. I'm looking for a explicit and complete guide on how exactly to connect power shutdown controllers to the car battery and ignition. I have a lot of diagrams and basic knowledge of mechanics but I feel like I'm a little out of my league here. I have a 2004 Mazda 6 and an M1-ATX 90 Watt Smart Automotive Power Supply. When it says connect to the battery, where exactly does it mean? Directly to the posts, spliced off the wires? is there somewhere in the circuit to do this? Any how-to information would be greatly appreciated. Pictures even more appreciated. Thanks!
    rob.
    Elsewhere
    Quote Originally Posted by ninjasavant
    It means to connect to a hot lead from the battery.
    You could run a dedicated line straight from the battery post to the PSU (with a fuse in there, of course). You could also run an always-hot line from the fuse block, as well. You could also splice into an existing hot line that's part of an existing circuit, but I wouldn't recommend it.
    How about the Wiki?
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    If you are unsure go right to the post. There should be a nut or bolt u can losen and then attach to. And make SURE you have a fuse inline.
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
  1. can I power a car stereo with an ATX PSU?
    By Fourgig in forum General Hardware Discussion
    Last Post: 09-08-2009, 07:40 AM
  2. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  3. M1 ATX problems
    By Tompa B in forum Power Supplies
    Last Post: 09-25-2005, 07:39 AM
  4. Battery an Alternator
    By UM_Fan in forum General MP3Car Discussion
    Last Post: 07-07-2005, 07:45 PM
  5. Using a Seperate Battery - for Car Pc
    By Vizion in forum Newbie
    Last Post: 02-18-2005, 06:59 PM
