If your installation skills are even marginally better than your artistic skills, you'll be fine.Originally Posted by tweakroxor
Helo, I made a setup for my system, does this is safe? and wil everything work?
I put my screen direct on accu because I'm afraid 90W won't enough
The mobo is MiniITX, The HDD is slimline.
Thx! Suggests?!
It was drawn in a hurrysorry
but is this working? and safe?
I have my touchscreen plug directly to my cigerette socket. as long as you have a fuse in there, you should be fine... been running for over 2 years without a problem.
isn't there something that I can put in place of te fuses?
You could put a fire extinguisher there instead of the fuse.Originally Posted by tweakroxor
So my draw is perfect? what can I do to make it more safer for burning?
Can I put my pc in hibernate for 24hours? without lossin' accu?
