Results 1 to 2 of 2
Thread: Power for my atx/p4 system
    Jan 2004
    Could someone explain exactly what I need for a atx/p4 system. I did the whole calculator thing and figured I need a little over 250w for my carputer. I found this and I'm wondering if this is what I need? http://www.voxtechnologies.com/power...es/vtc0148.htm
    Also if it is how do I hook this up to my battery? Do I need more than one battery? Is there a place to go to learn about how to hook up power to a carputer? I have searched for days...maybe I'm just a bad searcher.
    Elsewhere
    Quote Originally Posted by icerain
    1. That power supply requires a 48v input. You car's electrical system doesn't have 48v.
    2. Currently there is no DC-DC power suply greater than 250w. DragonBTV is working on a 300w unit.
    3. It's a lot easier to decide on a power suppy FIRST, then fit your system into those power parameters.
    4. What are you going to be doing in the car that's so CPU-intensive that necessitates a P4?
    5. You're searching skills suck major ***. There's a forum called the FAQ Emporium. That's as close to a 'guide' as you're going to get. ERach project is so individual and so unique that there's no one manual to cover every possible instance or situation.
    You're installing a computer in a car. The car has limited power by the design of its electrical system. P4s are notoriously power-hungry CPUs. Conventional wisdom is to choose a CPU that is less power-intensive for your vehicular application. If P4 is a must, look at a P4 Mobile.
    How about the Wiki?
  1. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 11:48 PM
  2. 1985 Celica Supra MP3-Car w/ Inverted Power
    By kmfdmk in forum Show off your project
    Last Post: 11-19-2004, 07:32 PM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
  5. Power system
    By Dishnu in forum Power Supplies
    Last Post: 07-01-2001, 07:56 PM
