You can use a laptop or a PC based setup. Both have done this with successful results. The most common motherboads in use on the forums are Via M10000. There are several flavors, but the general consensus is that it is quiet, low power consumption and generally fits the bill powerwise for a typical setup. You will need to decide whether or not you plan to use a headunit or not. If you are competing in car audio, you would probably want to rip your mp3s in 320kbps or even FLAC. I do not run a DVD-Rom drive. If I need to transfer files I do it via wifia or USB memory stick. Good luck and happy searching.
Edit: Nevermind, I reread your post and saw you are using an EQ.
LinkBack URL
About LinkBacks
