Don't power your Car PC from your head unit wire. It's probably not heavy enough gauge for it.
I believe you are referring to an ITPS rather than an ITPC. If so, these are extremely evil little devices that allow you to believe you have a power solution to your computer but will often introduce stability problems into your system. Search on terms "ITPS" or go to the FAQ Emporium (click on the link in my signature) and check out the thread on "Power supplies explained".
Before Thanatos shows up an defends the ITPS, I do have to allow that they CAN work and people do use them successfully. I am not one of those people and wasted a lot of time before getting a proper power supply and a stable system.
I will tell you that if you are testing the system, make sure the car is running. The ITPS drops the voltage quite a bit and can be a problem if power is only coming from the battery.
As for your screen, I can't help you there. It sounds like a sync issue all right. Perhaps check your display settings and try different frequencies. My screen didn't work properly until I selected 75hz.
Good luck!
LinkBack URL
About LinkBacks
