It may be a bit harder to find a PSU for that
machine than most. Compaq, HP, Dell, Gateway, eMachines pretty much all the major OEM computer manufacturers have this REALLY nasty habit of using proprietary PSUs. Now in most cases that simply means they're a funny shap or size and a normal ATX PSU won't physically fit inside the case, however I know from experience that both Dell and Compaq have used proprietary
wiring paterns in the past (I don't know if they still do but I wouldn't put it past them). The size and shape of the PSU is the same as a regular ATX, even the connector is the same, but they are wired diferent (ie on a Dell PSU you may have a 3.3v line where a 12v line is on a normal ATX) and if you use a normal one there's a pretty good chance that it will fry the Mobo.
Do a quick google for "ATX pinouts", grab a multi-meter and check. If you know that you have a proprietary PSU it's easy enough to modify the new one so that it will work, but if you don't check it and it does turn out to be proprietary, then you're gonna have a problem.
