Go do some reading on DC-DC power supplies.
So what does everyone think about this set-up? I have looked for power consumptios but havent had much luck.
ASUS A8V-MX
AMD Mobile Athlon 64 3000+ (DTR) 800MHz FSB Socket 754 Processor
CORSAIR XMS 1GB (2 x 512MB) 184-Pin DDR SDRAM
TOSHIBA Super Slimline 40GB 2.5"
I plan on getting a Xenarc 7 in Touch Screen for the dash 94 Mustang GT and an External HD for the glovebox and i would like MP3/DVD/CD Playback-GPS-Playstation 2-Navigation-Mobile Internet-Cellphone Integration-and possibly OBD but i dont think its offered for a 94 Mustang i think it started in 96. I am almost positive that this PC will be powerful enough to do all this but now what Powersupply would be powerful enough for this PC. I would like to stay away from using a DC-AC converter.
Thank You
RacerX
Cars
1994 Mustang GT Punch 240.4 2 12" Kicker Comp SOLD :(
2006 Suzuki Aerio Sx Kicker KX 650.4 RE 10
2003 Eddie Bauer Expedition DVD - Navigation Package Traded in for 2008 XL-7 Limited
Car PC
Planning
OK i found the calculator and i input the closest things i could find to what i wanted and got 195 and this is just for the
AMD Mobile Athlon 64 3000+ (DTR) Socket 754 Processor -- 89W
Onboard Video 10W
CORSAIR XMS 1GB (2 x 512MB) 20W
TOSHIBA Super Slimline 40GB 2.5" 5W
CPU Fan 5W
Panasonic Slot Load DVD-ROM/CD-RW Combo Drive 24x24x24 20W
ASUS A8V-MX 25W
Sound Blaster 7W
2 USB 2.0 Hub 10W
2 80mm System Fans 4W
Ok so is there a way to split the load between 2 power supplies maybe a 150 and a 90 opus? There has to be a better/easier/cheaper way funny thing is.
Thank You
RacerX
Cars
Car PC
Planning
You don't need AMD Mobile Athlon 64 3000+ (DTR) Socket 754 Processor. Get urself a Athalon XP-M 35WOriginally Posted by racerx3165
Peace,
Rafster
CPU: 89w ÷ 12v = 7.42aOriginally Posted by racerx3165
Mobo w/ onboard video & RAM: 25w+20w+10w = 55w ÷ 12v = 4.48a
Just your CPU, RAM and motherboard are sucking nearly 12 amps off the 12 volt rail. That doesn't include fans, hard drives, optical drives, LCD screen or anything else requiring 12v.
You are completely missing the point here. I understand your desire for a big bad-*** powerhouse computer system. It lengthens, thickens and hardens your geek penis all at the same time, and that's not a bad thing at all.
However, you have to think about what you're going to be doing in the car.
When it's released, are you planning on playing Quake4 on the PC in your ride? Maybe some groovy 3D renderings?
I didn't think so.
Right now, there's no DC-DC power solution for what you want in your car, period. Sorry. I can't change that, but maybe some of the more electrical engineering-inclined members can (*cough*DragonBTV*cough*zootjeff*cough*).
If you want to run your ***-kicking gamer rig in your car, then you're going to need an inverter. That's going to be a pain in the *** and bring about other headaches.
If you're willing to scale your setup back and look at lower-power alternatives like the Pentium M or the Athlon XP-M, then your going to be able to configure a system that will work within the constraints of the currently-available DC-DC power supplies.
Ok at Newegg can get a Athlon XP 2400+(35w) - Asus mobo - Corsair value selct 1 gb (2x512). So is it safe to assume this will run GPS-Emulators-DVD Playback-OBD. I can get it all for 240$ so i may be able to order it next payday.
Cars
Car PC
Planning
I hate to ask but what would be ones reason for getting the VIA EPIA SP13000 Mini-ITX Motherboard instead of getting say an asus or msi and a mobile processor?
Cars
Car PC
Planning
just so you know, i have a pentium 3, 600mhz, 384mb ram, and i can play dvd's, xvid etc just fine... I paid $40 for it shipped...
Im bidding on p3 866 on a micro ATX just so i can get started, if i get ill get a 7 or 8 lilli. Then once i get my transmission fixed they ill hopefully get the Xenarc and the XP-m system.
Cars
Car PC
Planning
The VIA EDEN boards are small, low-powered and can be run with little or no active cooling (aka fans).Originally Posted by racerx3165
I'm in agreement with you, though. When a P-III running at teh same clock speed with a comparable FSB will blow it out of the water, it's not a particularly viable choice for me, either.
To each his/her own....
