Results 1 to 4 of 4
Thread: random power offs
    Feb 2005
    Oklahoma
    random power offs
    I have been dealing with this issue for a while now. Anytime I use my carPC for longer than an hour the computer usually will start to lockup for a split second while playing music and keep playing after a second or so. after it does this for a short while(5-3 secs), I can hear the computer shut off and come right back on very much like a short black out with my home PC only the lilliput screen stays black like it isnt getting signal. If I kill the master power and restart all is fine. Does this sound like a heat issue, or like my PSU is dropping voltage?
    any info would be great.
    Elsewhere
    It could be either, but I'm inclined to think it's an overheating issue, since the PC locks up. Usually if it's a power issue (although not always), the PC will simply shut off.
    The time is predictable, as well, which indicated that it's taking an hour for whatever problem you have to manifest itself. That's another indicator of an overheating issue.
    It could also be a weak battery that take an hour to drop below the level of charge needed to keep the PC up and running.
    How about the Wiki?
    Feb 2005
    Oklahoma
    I have thought about the battery issue as well, but I have installed a yellow top 2 weeks ago, PC can survive crank but still shuts off after the time frame. I have had an overheating issue with this mobo when it was my home system and I thought it gave a beep prior to shutting down from heat protection. To test the heat issue I will run my AC on floor to see if it helps. Is there a way I can test my PSU?
    Tainted Love Cris's Avatar
    Romania
    Easiest way is on another mobo.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
