Maybe its a sign of it dying? Is it very cold when it does that(the ambiant temperature)?
Hello
I've searched but nobody had this problem on thos board.
My problem is that when I turn my laptop on after couple of hours of not using it the LCD in it is mixing lines, the view is shaking, the START tray on the bottom of the LCD isn't on it. When I have a Completely white wall paper it shakes less, on a dark wall paper you cant almost see anything.
This goes away after about 5-1o minutes (when it worms up)
What should I do?? Is there anything I can do myself??
I'll post pics if I will get my camera back
Dhaark
The temperatur in the place where it is is about 17-19 C.
Can it be something with the LCD ribbon(i think that's it called that way)??
Dhaark
I dont know , But I wouldnt think. Did you try it in already warm place (like inside your home at 25 celcius or more)?
I'll have to take the laptop to o friend to try if it does the same thing an a normal screen.
I'll also try new drivers for my grafics card.
if i turn it on in a warmer place the effect is that it has less a "shaky" screen.
Dhaark - Darek
the LCD might also be dying...
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
it's almost a brand new laptop - but I lost the warranty because i unscrewed the computer and changed the cpu.
Does anybody know how much does a 15,4" widescreen cost?
Dhaark
Check ebay. It dpends on the laptop it self , you cant just use a lcd from another laptop unless its the same lcd (model).
ok thank's for all your help kevinlekiller. i'll tomorow if it the same thing happens on a stationary monitor.
Dhaark
