Results 1 to 10 of 14
Thread: 2 questions; about batteries and about in dash dvd
    DST
    DST is offline
    Jun 2005
    Hi there,
    I just had a couple questions to ask - first, what do you guys think about having a dedicated battery in the trunk for the car pc and stereo equipment? A friend of mine just wired his car in this fashion for a regular stereo system and it seems to work well. Are there any drawbacks to this kind of setup?
    Also, I would like to mount a USB dvd drive as a single DIN into my dash. Are there any drives or kits available to put a standard pc dvd drive into a DIN slot? I'm not very handy with fabricating things so I am hoping to avoid creating an abomination of a bracket.
    Thanks!
    Nick
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    absolutely NOT necessary...for stereo equipment, you may need capacitors if your current electrical system cannot handle all the power you're trying to pull through it...stereo shop can help you out here. As far as the carPC, there are several power supplies that monitor battery voltage for drain. I've never had any problems and I've left the computer on for as long as an hour and a half (car off) with no problems.
    Drawbacks: $$$, weight, wiring
    as far as your drive goes, you're going to have to make something...you could probably start with a mounting kit and sleeve designed for an aftermarket radio that is vehicle specific.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
    DST
    DST is offline
    Jun 2005
    Thanks for the info!
    I guess I'll have to break out the bondo afterall.
    My plan is to put a dvd drive below a fold out touch screen. I was thinking I would go with this one:
    http://www.mp3car.com/store/product_...roducts_id=120
    What worries me is that I am not sure if the dimensions listed conform to a single DIN. The Xenarc foldout model does however state that it is the right size. In any case, do you happen to know if either model is designed to slide into any particular kind of aftermarket bracket like maybe one for sony headunits etc? I'm thinking if I can at least get a bracket that will fit one of the two components I will be able to save a little time.
    Thanks,
    Nick
    Sep 2005
    Hudsonville, MI
    Quote Originally Posted by ITL
    Dude a capacitor is not going to fix the problem you just described a new alternator is gonna do that and an additional battery will make a diference but is not neccesary, but is cool and does make a diference, but make sure the alternator can handle charging two of them.
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    Quote Originally Posted by nate@s-curves
    I second that. A capacitor does not fix the problem of the alternator not being able to put out enough current. It can smooth out small surges in power needs. But if you're consistently drawing 100amps but the alternator is putting out 95amps, you're in trouble.
    I've considered a second battery for my carPC. Here's what it (along with a battery isolator) would do for me:
    1) When I'm working on it, I could leave it powered by the car (2nd battery) for hours without worrying about damaging my starter battery
    2) I could leave the carPC in standby mode without worry. (I do this now, using only my stock cranking battery, but I use a low power S3 mode, I drive (recharge) every day, and I have a kill switch when I'm letting it sit for a while.
    3) I could demo it to friends, whatever for a few hours without worry.
    My main concern was 2, which I "solved" with the daily driving, low power standby, and kill switch. I suppose I still worry a tiny bit. For 1, I use a DC power supply when I'm in my garage. For 3, I have no friends.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
    Nov 2004
    South West
    I have just spent ages looking into the second battery thing and i have just put one in the trunk of my car.
    My conclusion is that it is not worth it unless you plan to be using your system alot with the car off. Example: The system in my sig should be fine at normal volume to use for an hour with the car off, I have only added a second battery as i work directly out of my truck and i turn the music on in the moring and leave it on all day.
    I start the truck about 10 times a day and normaly only drive for 15mins between stops.
    I also never shut off my laptop, it just goes into standby when i arm the alarm.
    With a second battery i know that i will allways get the car started even if i have left everything on until the battery goes dead and things 'turn off' by themselves.
    for the next question, I have just ordered the xenarc 700idt, do a search as there is a little bit of info about adding a cd/dvd drive to a space that allready exists in the bottom of this unit. I am hoping i can fit it with a slot-load drive when i finally get it!
    If you look around in a breakers yard, (i found a tray in a citroen) a lot of cars have trays that just drop into a din slot and i used one of these, cut the back out of it, dropped a slotload drive in, filled the gap with expanding foam, sanded down the mess and covered the front with some carbon effect stuff. Looked damm good for a 10min job!
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
    DST
    DST is offline
    Jun 2005
    Thanks for the tip on the xenarc 700 IDT.
    Found this link per your advice:
    Installing CD/DVD in Xenarc 700IDT
    I wasnt able to find a thread with confirmation from someone that was able to make the integration though. Have you heard of anyone that has done this that I might be able to learn from?
    Thanks,
    Nick
    Nov 2004
    South West
    NO!
    Havent heard that is has been done, one post said there is the perfect space for a slim line drive to drop right in, another post said somthing about a circut board that had to be moved.
    I am still waiting for my 700idt to arrive but i will be taking a screwdriver/hammer to it as soon as it drops through the door!
    I am hoping i can fit a drive, a slim to ide converter and a usb to ide convertor all inside the xenarc casing (hoping!) and just wire it all to a usb chassis socket on the back of the casing so it all looks original..
    Also, the xenarc comes with its own cage, just like the car radio ones.
    You drop it in your din slot, bend back the tabs to secure it the the xenarc is supposed to be secured in with screws through the cage into the casing. Havent got a clue how you get the screws in once the thing is in the dash though?!?
    BTW..I chose this screen over the one you mentioned earlier as they are much the same price and although the xenarc is not motorized the quality (both build and picture) seem to get much better reviews on this forum. This is important to me as my 4x4 spends a fair bit of time getting chucked about over the rough but i guess if you want the motor you might not need the robustness?
    DST
    DST is offline
    Jun 2005
    Looks like a good solution. I noticed somebody posted that Xenarc is looking into making one of those displays with that bottom section designed for a cd/dvd drive to drop in. I wonder if that will happen. I doubt I can wait that long though so I will probably end up doing something similar to you with the chain of adapters.
    As far as the motorized aspects of the mp3car.com model, I gave that a little thought and I think you are right, the motorized one would be much more delicate. The mechanical one is probably much more suited for my uses. The empty space just makes it that much more appealing.
    Nov 2004
    South West
    As far as i know.. xenarc are planning to make one with the drive fitted, not with a space for a drive that you can fit yourself. I think that is why the space is in the current model but i belive they are still working on some way to run it all through one usb connection so they have gone ahead and relased it as it is with no drive.
    I had a chat with xenarc and the guy i spoke to thought that it would be a stand-alone cd/dvd player with an onscreen menu and rca outputs but either no vga or vga on a source select button. Not the sort of thing i want and there are plenty on the market (non vga) allready. he had no idea when it was due and that probbly means a year+
