Results 1 to 10 of 19
Thread: Not noob, research done. Final approval.
    Feb 2005
    West Valley City, Utah
    I am a former computer tech, and have been playing around with computers for about 10 years now. I know my way around a computer, and am fairly good at troubleshooting/fixing computers. I am also a bit of a car enthusiast. I just want to plan out everything I have/want, to see what everyone else thinks of it.
    I am not a noob, so dont call me one. I have not made a carputer before, but I figure its not impossible for someone like me.
    Carputer/componants:
    Epia500m? the 533mhz fanless motherboard. with surround sound. I would go higher end for this, but I bought this board about 1 1/2 years ago, when they were $200 or so. I dont want to see it go to waste.
    pci to pcmcia converter with over motherboard riser card, along with a laptop wireless card using cellphone networks for unlimited high speed internet access, and a free slot. The free slot will probably go for a wireless lan card, depending on how it turns out.
    usb keyboard, mouse/trackball, possibly gps(debateable at this time)
    Laptop 2.5" hard drive (size indetermined at current point), slim slot load (if plausable)cdrw/dvd read combo drive, both with adaptars.
    small fan to ventilate fanless pc (better safe then sorry)
    dstx(?) 200watt power supply, along with a/multipul accesorry power supplies. Quick question, this will work as an adiquate startup/shutdown controller correct?
    USB hubs, X3, one in the glove box, one under motherboard, in radio din, and one in the center console/backseat area.
    a/Several usb 2.5" hard drive enclosures, for easy, quick removal/addition of files.
    256 mb of ram. This *should* be pleanty for the carputer, but time will tell, and it isnt alot of cost, considering that I have it just laying around.
    Software:
    Windows 2000 (I am using this, pretty much no matter what so bite me)
    front end, unknown. I will get to this after I have everything all together.
    Car mods:
    alt upgrade. Either single 200amp conversion, or ac removed, and dual 130 amp alts installed, depending on cash flow at the time.
    00 guage wires, ran from front to back, to second battery in the trunk for subs/sound system.
    3-5(hopefully 5, depends on how much room in the doors) 6X9's, 2 6" midbass, 2 3.5" tweeters, anything as far as subs go, depend on cashflow. Cheap will be 2 10", expensive will be custom designed 5-6 sub system, made for sound quality, shooting for a good sound. Compleatly FUNCTIONAL surround sound.
    Lots and lots of dyno matt or acceptable sound deadiner.
    I have plenty of room in the interior of the car.
    adaptable for up to 4 din slots, and the clock in the top can go as well
    http://foxtbirdcougarforums.com/atta...1&d=1120787016
    and a nice big trunk
    http://foxtbirdcougarforums.com/atta...1&d=1120787261
    Screen:
    I plan on experimenting with a "3 in 1" XGA/VGA, tv/rca input, fm tuner, for the monitor. If it dosent work out, I will finally have a tv for the bedroom, and will go with a xenarc vga monitor.
    Basically tell me what you like/dont like about this set up.
    Progress,.... that is what I keep forgetting ;)
    planning_[++++++++++]. 110%
    parts___[++++++----] around 60%
    install___[-----------] -9,000%
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    It is a nice lower power cool running motherboard, but I think you lose any possibility of mpeg playback. I don't have one, but that's what I remember from my research.
    You might have problems with both of them fitting in the slots at the same time. But it depends on the card size and layout. Unless your ports are spaced a little.
    All sounds pretty good. Except the mouse, come on man, touchscreen!
    I don't know, from what I read it sounds like a pretty good power supply, but as for the wattage, you might wanna try some of the calculators around here to figure out the total wattage of the system.
    All good here.
    Again, I think this is a little on the low side. I would say 512 is the minimum, but go nuts, you'll see how much you need for what are are planning to do with it.
    Software:
    If there was a little smiley biting another one I would use it. OS doesn't really matter to me, so use whatever you want.
    Car mods:
    That all sounds well and good. As for the dynamat, do you have a special feeling for the stuff, or are you just thinking you need sound damping? If you don't care what you use, there are plenty of substitutes out there that are cheaper. Peel 'n Seal is one of them. I used it, great stuff. Cheap too. There was some other stuff out there too available from Master Carr.
    Overall I give your planned system something like a B. You could go higher on certain components, but I don't really know how much power you are going to need unless you say "I wanna play DVDs for 24 hours a day!" or "I wanna built an embedded Linux rig for strictly MP3 play" So go nuts, and report back on the progress.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Feb 2005
    Quote Originally Posted by kiltjim
    as far as the mpeg playback goes, it should be fine, I have a 233 with 32 megs of ram that I had a dvd player on for years, I remember upgrading to windows 98 so I could use it.
    For this, I was planning on an acutal seperate encloser, one that could go into a 3.5/5.25 bay. That way it would be a controller card with wires.
    touch screens are overrated. No j/k, I can see where I would want one, but I have three little sisters and a little brother that all regularly get driven around in this car. I dont want them touching nothing that will break easy. I think I will just find a touchpad or a trackball.
    I am really really lazy, I should be able to stay under the peak, with the extra accessories power supplies, I should be okay with a 90 watt I think. I will look into it I guess.
    I litterly have 256 laying around, and for a 533 mhz computer, I dont see how any more then 256 will benifit it. I have lots of older slower computers, there more or less my specialty. The computer I am on now is a 550mhz with 64 megs of ram, and it can do everything that my carputer will need to. I also thought about puting my main computer in there, and it is a p2 overclocked to 300mhz with 96 megs of ram. Compaired to that, this computer will fly.
    I am not quite there yet,... So we will have to see. Dynomat, I have heard alot of good things from, but I could go either way.
    Once again, I have had computers round the 200mhz mark that could play full screen dvd's at 1600x1200 with a 2 meg video card and 32 megs ram. If this computer wont play it, it is the equivilent of a 133mhz or lower.
    By the way, thanks alot for that. that is exactly the types of things I need ot know.
    Constant Bitrate seanshine's Avatar
    May 2004
    Behind the Zion Curtain
    Quote Originally Posted by Haystack
    Nobody said you were a "noob",it looks like you've done some research,and know pretty much what you want.Hell,if I can build one anyone can
    Not bad,but it may not have enough grunt for dvd,and definitely not for divx.
    What kind of case are you making/buying,and where do you want to put it?
    Maybe in the dash ?
    You can go 2.5,but 3.5's are cheaper,if your power supply has enough juice.
    I agree,you never can go wrong with too much cooling.
    Why so many?
    One should be enough.
    Car mods:
    I like the single higher amp alternator idea much better,as you'll regret not having a/c when you need it.Isn't the point of having a carputer and music making your drive more enjoyable? Removing one creature comfort for another is going backwards.
    0 Gauge wire,and a second battery? Seems like a bit of overkill and money,unless you are going for a db contest.
    If you're going for a sq setup,a single sealed sub,a set of component speakers for front and rear will sound much better IMO,just remember to play with their placement until you have a nice stage.
    Screen:
    What brand,size,and how are you planning to mount it?
    Any sufficiently advanced technology is indistinguishable from magic - Arthur C. Clarke
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    A suggestion on the build. This is independant of your hardware choices.
    Build it completely on a bench/desk in the house. Install all the hardware/drivers and make it work the way you want with a full size keyboard/mouse/monitor.
    Run it for several days this way to male sure it is set up the way you want.
    Then test it on the seat of the car with the DC power supply. If it still does everything the way you want do the car install.
    Some of the most frustrating times are related to an issue that is easy to fix out of the car but found after the hardware is in the car.
    Good luck and welcome to the board.
    (it is nice to see a new person that does research first)
    TruckinMP3
    Read the FAQ!
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    Does anyone BUT a newbie (maybe n00b, maybe not) say something like this. ...TWICE.
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by TruckinMP3
    I second that! Build, try it out on the bench, then transfer it to the car, try it there, THEN install. It can save you a lot of hassle.
    Sounds like you have the computer part nailed and if you run into problems you can fix them yourself. Good luck with the install and I'm interested in how well that 3 in 1 monitor works. Make sure you post up a worklog!
    Want to:
    Oct 2004
    NY
    as far as the pc spec's, I think if you are very knowledgable about controlling your processes & don't bloat the system, you should be functional... you are a self proclaimed pro at running slower pc's, so you know how to handle that I guess.... I wouldn't waste my time personally with a system this slow because I know it would frustrate me to no end, but that's me, not you....
    as far as your audio plans I don't know how much of an audiophile you are, judging by your plans I'd say not too much..... 3-5 6X9's is rediculous to me, & your talking about sound quality & surround, but your spec.ing equipt that is more for spl & boom, not that you can't have both, but that's a really ambishous goal....
    surround in the truest sense is almost impossible in a car with exceptions like alpines demo vehicle.... sure you can add a center channel to anything really, but when your talking about audiophile sound quality you will not pull it off, period. the reasons for this are way to involved for me to start posting them here, & you may be happy with just a surround ambiance... depending on your ears & knowledge it may actually sound good to you, if that's good enough for you then go for it, but I wouldn't aproach the audio end of this equation anything like what your spec.ing.... that's just my opinion though, for whatever it's worth....
    good luck with your project....
    Feb 2005
    I have never really played around too much with a sound system. The extent of my experiance has been a 4 inch sub and 5 1.5" speakers for my surround sound. I thought alot of the pull for surround sound was to make 5 speakers the same level. If that dosent matter too much then I will change it around alot. But like I said, I want to have a strong middle channel, that will not overpower then front and back. Maybe 3-5 6x9's is a bit much. Honestly, I think the sound portion is the only thing I dont know what I am doing.
    Let me do some research really quick, and I will let you know what I come up with.
    Feb 2005
    Quote Originally Posted by seanshine
    Maybe in the dash ?
    I want to put the computer(motherboard) and maybe the cd drive in a din spaced slot. But we will have to see how it goes. Pretty much I am leaving this till very last, I dont consider it to be a major problem.
    why so many?
    I figure more is better. I just dont want to have to go out and buy more later, and I want to fit them several places in the car, so they are easily accesible.
    I dont care for ac too much. Year round, we go from -20 degrees to as high as 110. As bad a 110 sounds, its just as easy to roll down your window and drink a drink. Also, the faggot that I bought the car from cut the ac lines and bypassed it with a shorter belt anyways. Even still, on my other cougars, I have turned the ac on once each, when I bought the car, to make sure that it worked.
    More is better, I will probably even change it so that the batteries get charged seperately, like they do on rv's. Imagine popping you trunk and jumping yourself
    I will have to play with it, like you said, sounds like I have alot more research to go.
    Honestly I dont know as of yet. just whatever I find
  1. Are there any ebay traders to watch out for?
    By jeeplaw in forum Off Topic
    Last Post: 06-15-2005, 11:10 AM
  2. Replies: 11
    Last Post: 01-26-2005, 02:26 PM
  3. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 09:19 AM
  4. CarPC research paper
    By BrUTaL in forum General MP3Car Discussion
    Last Post: 02-03-2004, 08:43 PM
