Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: psone power options
    Nov 2005
    WA
    Question psone power options
    I have a psone screen and would like to power it from my car battery, I was originally planning on getting a psone car adapter and just using that; however, I can't find one in any store around me. Mouser has 7.5volt regulator ICs that are $0.73, I was wondering if I could use one of these to save me some money. Would one of these work to power the psone from a car battery? If so, would the regualtor chip be the only thing I need? Also, these IC's put out 2A, would this be enough to power the screen?
    Here are the specs:
    Mouser Part #: 511-L78S75CV
    Mfr. Part #: L78S75CV
    TO-220AB 7.5v 2.0a
    http://www.mouser.com/index.cfm?hand..._pcodeid=51111
    Thanks,
    Jesse
    Nov 2005
    WA
    Anyone? Or should this go in the power supply section? I put it here because it is the first thing I'd like to straighten out before I start buying parts.
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Posting here is good.
    Did you check the current projects for PSone screen in the forum to see what other people is doing?
    What is the current need it for the screen?
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Nov 2005
    WA
    Yea I've looked through the forums, seems like everyone is using the car adapter.
    The screen uses 7.5 volts.
    Nov 2004
    I'm talking about Amperes.
    Thanatos.
    Nissan Aux-in MOD
    Variable Bitrate BIzFlawless's Avatar
    Oct 2005
    Tejas
    Question
    Maybe this could help?
    Powering your LCD Monitor
    Nov 2005
    WA
    Well the ac adapter for the psone screen and console has an output of 3A. Would the lcd actually draw 3A?
    Nov 2004
    Well that is what i'm trying to figure out.
    Cus if you put that regulator and the current is about of it, the screen will (or not at all) work with problems (diming the image, powering off etc)
    Thanatos.
    Nissan Aux-in MOD
    Nov 2005
    WA
    Quote Originally Posted by BIzFlawless
    Thanks, I wonder if this means that the psone screen could be powered the same way but with a 7.5 volt regulator? Has anyone tried this sort of thing with the psone lcd?
    Nov 2005
    WA
    Quote Originally Posted by thanatos106
    Thanatos.
    So if I found a regulator ic that put out 7.5 volts with 3A instead of 2A, would it work?
  1. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  2. Power Options
    By Etno in forum Newbie
    Last Post: 04-22-2005, 12:52 PM
  3. I'm so confused about power options
    By cfcrafting in forum Power Supplies
    Last Post: 04-14-2005, 07:30 AM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. Two power regulation options, which would you do?
    By therussman2002 in forum Power Supplies
    Last Post: 01-11-2005, 12:52 PM
