Results 1 to 10 of 16
Thread: 2006 Hyundai Sonata Carputer
    Nov 2005
    Question 2006 Hyundai Sonata Carputer
    Hi, I am very new to this. I am below a newbie. I was justreading about this today and was very interested. I just have a couple of questions, does anyone have any ideas on what to get for my car?
    Also, what is the degree of difficulty in doing this carputer thing?
    Last, does anyone live close to Bremerton, Wa that can help me with this carputer thing?
    Any comments would help, except for :-)
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    If you dont know how hard it is. then give up now.
    Nov 2005
    I can kinda assess the degree of difficulty if i get some feedback. it sounds pretty hard but so does rocket science and thats not too hard.
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    Tell us what you want to use it for, then we can try and tell you what sort of equipment you will need.
    Whether it is easy or not depends on your experience/knowledge of electronics and computers. Really only basic knowledge of electronics is required (this again depends on what you try to do of course), but your knowledge of computers really helps when configuring the whole thing and solving problems - as from experience there will be problems lol
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    Nov 2005
    See now that was what I was looking for as a reply. Thank you.
    Ok, I do have knowledge in electronics and extensive computer knowledge.
    In my Sonata I have 2 amps (1 for subs and 1 for speakers), stock radio and xm radio through FM trasmitter. I am also running TomTom Navigator with my PDa and a tomtom wired GPS reciever. If you need pics on the inside of the car, i can provide.
    For the carputer, I would like to play my music through it. I would also like to play emulators through it. I would like to have my Tomtom reciever run through the carputer insead (the GPS reciever is an RJ-11 connection).
    Also, Iwas reading about the PhoneConnection.net thing also. I would like that.
    This is all I can think of right now. If there is anything else that the carputer can do thats pretty useful, i would like that too :-)
    Mar 2005
    Maryland
    if you can run subs, you can run a computer. but the software...to make everything perfect... thats alittle tricky.
    Nov 2005
    Trust me i have no problem with the running of stuff. I can do that just like I did to the system I have. Im just not sure about everythig I would need. Also, my main problem I think would be the LCD screen. Since my car is so new, there are no radio kits for my car. I would have to make it out of fiberglass i guess, unless there is somewhere else to put it.
    I think the hard part right now is the planning phase since that is where I am. I need a jumpstart because I am totaly clueless right now. I can't even think of any ideas.
    Mostly any computer above 600Mhz will do what you want.
    Now you have to decide if you want to go the laptop or desktop route.
    Laptop easy power solution, just buy one of those car adaptors for it, and have it shutdown when it has been x minutes on the battery after you shut off the car. Powering up the laptop is a little bit more tricky, you'll have to rig up a little time delay circuit using a relay and a capacitor, then solder the NO contacts on the relay to the power switch on the laptop. There is a circuit of this somewhere on the forums. Problem with a laptop is the limited ability to upgrade (no pci slots etc).
    A Desktop/via/m-atx solution is a little bit mroe difficult. It's just like a standard computer, but you can use a normal computer supply tied together with a dc/ac inverter or buy a dc-dc power supply (such as the Opus). Then build/buy a case for it and mount it. Also the desktop option gives you regulated +12v, +5v in the car, which is handy for various devices such as USB hubs etc. You can also get the same regulated voltages using a laptop but you'll have to rig up a voltage regulator using some chips (such as lm805) or purhcase a pol (point of load) voltage regulator.
    Post a pic of the dash and we might be able to help with placements of the LCD screen.
    Not too sure about the Tom Tom reciever and interfacing with the computer (maybe someone with a bit more knowledge can help out here!) But I think it might be easier to buy the BU-203 USB gps reciever and use some software such as destinator to get GPS on the carputer.
    Most of the products needed are at www.mp3car.com/store
    Where abouts do you plan on mounting the carputer?
    Fox Mulder
    2004 Toyota MR2
    Nov 2005
    I plan on putting the puter in the trunk. There is like 1 - 1 1/2 foot by 6 inch space between my sub box.
    Here are some pics of my dash.
    I do plan on doing a mini desktop computer. not going the route of a laptop.
    Nov 2005
    Sorry for HUGE images
  1. 03 Sonata Carputer
    By falcons03sonata in forum General Hardware Discussion
    Last Post: 11-16-2005, 07:54 PM
  2. 2006 Ford Fusion Carputer
    By fusionman06 in forum Newbie
    Last Post: 10-21-2005, 01:05 PM
  3. 2004 Hyundai Tiburon Carputer In Progress
    By bjm2020 in forum Worklogs
    Last Post: 05-24-2005, 10:03 AM
  4. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  5. Replies: 0
    Last Post: 06-29-2004, 04:03 PM
