Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Carputer in trunk.... slot IDE DVD drive in dash?
    May 2005
    PNW
    Hello all!
    Well, I've been lurking on these forums long enough and I figure it's time to start posting. Here's my plan for my carputer for my '04 Lancer Ralliart:
    -Custom aluminum case anodized black
    -DFI G5M150-N ITX mobo
    -Pentium-M 730
    -Slot load slim black Panasonic DVD-R
    -1gb PC2700 RAM
    -~80gb 2.5" HD
    That's all I've got so far. My first (of many) question is: How long can the IDE cable be from the DVD-R to the computer? Ideally, I'd like to have the case in the trunk and the drive up in the dash. I've read on other forums that about 24" is the longest I can go. Anyone tried longer? Anyway to make this work? Just curious. Thanks!
    -Ben
    BTW, awesome forums! Wish I could access these at work.
    Constant Bitrate Eternalodyssey's Avatar
    Oct 2005
    St. Louis, MO
    Thats a decent setup so far. When you go to use the slot DVD-R, you're going to need a module that snaps onto the back of the slim drive that converts the signal over to IDE. Then search for an IDE to USB 2.0 converter and then the USB wire can be as long as you like. And with this setup you shouldn't need to run an audio cable either. At least I didn't. You can find an IDE to USB 2.0 converter for less then $20 on pricewatch.
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
    IS JACK BAUER GONNA HAVE TO SMACK A *****?
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    OREGON!!!!!
    Its about time there was an oregon person here.........
    I thought I was alone.....
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    I've read somewhere here that trunk to dash has been done with IDE; it was achieved by a custom IDE cable made up with several CAT 6 cables and appropiate connectors.
    May 2005
    PNW
    Quote Originally Posted by kmcniece
    OREGON!!!!!
    Haha, yeah buddy! Another Oregonian. Sweetness.
    So I could go USB huh? Would I lose any of the sharpness or anything on the LCD or would it still look decent? Thanks for the help thus far!
    -Ben
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    I use a USB adapter to make it from my trunk to dash, but you're gonna need to power the drive as well (USB won't power it sufficiently, natch)
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
    Variable Bitrate 3g Jester's Avatar
    Nov 2005
    would a powered usb hub do it?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Yes... you can either buy the enclosure that comes with te PS2/USB cable to power it up and connect both to a USB hub or my best choice, use a 5V POL or mean well PSU to power that and the hub.
    Also remember that you can use the 5v line from you main PSU to power stuff up.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Sep 2005
    San Luis Obispo, CA
    No. Do a search, but basically the slimdrives require 2A, USB outputs 0.5A, so even running off a powered USB hub AND using a second USB slot with the power to usb adapter they give you it will only be 1A and flakey at best. For good results you'll want to wire 5v to it directly.
    -arebelspy
    Sep 2005
    San Luis Obispo, CA
    Here's some links for you:
    Cool new toy I got (USB enclosure for slim DVD/CD drive)
    SERIOUS Problems! w/ Panasonic Slot DVD in external enclosure
    Bottom line: USB enclosure + usb extension cable (M to F) or long usb cable (a to b) works, but you'll need to power the USB enclosure, and not with the dinky "2nd usb slot" cord they give you, but 5v from a regulated source like your PSU or an adapter
    -arebelspy
  1. MB870 & Slimline Floppy Drives
    By McGreggor in forum General Hardware Discussion
    Last Post: 11-09-2005, 07:32 AM
  2. why DONT I want a ide drive in my dash?
    By ahreno in forum Newbie
    Last Post: 10-25-2005, 06:05 PM
  3. Slot Load Laptop DVD Drive
    By Krusher in forum General Hardware Discussion
    Last Post: 07-25-2004, 09:52 AM
  4. Slot load DVD drive?
    By arkadiyp in forum General Hardware Discussion
    Last Post: 07-23-2004, 07:23 AM
  5. IMAC slim slot dvd drive w/adapter $65
    By tbdombrosky in forum Classified Archive
    Last Post: 09-05-2003, 09:44 AM
