Originally Posted by Viscouse
Here is the deal. IGLaunch was early on, and bacially, all it did waslaunch the program, and kill the nag screen. Eventually, I believe with later versions of IG, it didn't work, or had to be modified, because INAV changed the name of the Nag Screen. That is all it did. The FE would execute IGLaunch, and then once started, the FE would Embed the program by the Window/Class name.
Skinbedder is a program, which can be embedded into an FE, that is used to "Skin" any program. It need not be IG, but can be almost anything. It originally started to be used with IG, but the developers, while focusing on IG (and since it was the first of it's kind, the users basically skinned and helped develop it with IG in mind) have continued developing it with en eye towards making ANY program TS compatible. IGSkinner was "replaced" by Skinbedder, as seen in the first post here [Release] iGSkinner BETA 3.9.5
IGmod is currently being developed at a rapid pace. This is designed to make IG more TS friendly and compatible.
Since IGMOD and SKINBEDDER are still in development, they are consistently evolving. Also, it seems as if the developers are sharing ideas constantly.
Which is better remains to be seen, and will be dependent on your specific needs.
Michael
LinkBack URL
About LinkBacks
