Some inverters don't survive crank without a tank circuit. Otherwise your simple setup should be fine. You could go DC-DC.
Well, I'm new to the whole car pc thing, but I know a little about computers, and a little about cars, and a little about electronics, and I don't have a lot of cash. Now let me explain, I will have a killswitch in the dash so that nothing external drains the battery when I get out of the car.
The computer will stay on until I turn it off, that means that if I just get out for a few minutes I don't have to reboot the computer.
I will also have a soft power button in the dash so I can start the computer when I get in the car, or I can turn it off by pressing it. (windows reacts to this)
I'm trying to keep everything simple since I have an old car, and just when I'm planning this my clutch went out. Anyway, it's very basic, any problems at all?
ODYSSEY
All information expressed in this post is my opinion, and should not be regarded as a statement of fact.Digital-Car UK|
(\__/)
(")_(")
So if I get a power inverter that survives crank I could be fine? What should I look for then?
Should I spend money on a good inverter or adding a tank circuit or putting in a opus psu?
Which one would be the cheapest/best for the long run?
Either Opus 150W or DSATX 220W.Originally Posted by TheRevoltingX
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Have you thought about a second battery?
I am using sealed lead acid batt in the trunk to keep things going after I shut down the car. I get 90-120 minutes to transfer podcasts or what ever.
I'm using an inverter ( $40 from overstock.com ) and found a couple advantages to a dc-dc.
1) cheap and easy to find
2) audible alarm if batt voltage goes down to 9.5v
3) built in power switch
4) blows up my aerobed when camping
Yeah I have thought about that, how big will this second battery need to be?
What I think I'll do is leave it like it is without a tank circuit and add one later when I have some more money.
I'm just going to make a it a bit modular.
How much would putting in a second battery run me?
$40 from a local electonic surplus shop.
It is a Zeus 7.2ah, lots on ebay right now.
You must Isolate this battery if you need advice I'll post my circuit.
So far I have a few months without problems.
Thanks, I'll see if I need the tank circuit, the inverter I got claims to survive crank.
I have one question right now though. I need to get a 4 gauge wire to run directly to the battery, but since I need to run it through a switch that only take a smaller wire, how do I go ahead and convert it? I don't know much about the linguo.
