Results 1 to 9 of 9
Thread: Ah, yet another Pentium vs. Athlon question...
    Dec 2005
    Well here comes yet another noob question! ("easy on though")
    ***As a note my eyes are about blood-shot from looking through the forums for this info. so I'm not taking the lazy route...
    For a little background I'm looking at putting a Carputer into my 2002 Tahoe. I'm running Infinity Speakers, Alpine SWR-1242D sub through an Alpine amp and using an Alpine HU.
    Size isn't much of an issue and I can work with power. This trucks is regularly turning about 13-14.5 V. (larger alternator option) Good lil' GM electrical system!
    Here is what I'm looking for:
    Nothing too special just something that can run nice video, music, GPS, OBDII and maybe some smaller things. I've downloaded and started to fool with RR and have it working pretty well with the video and music but will tweak it later!
    Now here is what I'm working with:
    I have a 1.2 Ghz. Athlon "Thunderbird" processor running 640 RAM (PC133), ATI Radeon 8600 Pro (256 mb), Linksys Wireless G card PCI, standard ATX board and case (size isn't much of an issue since I have a hella lot of room in the back), Soundbalster Audigy Sound card, etc.
    My Main question is...Should I continue to use to Athlon 1.2 or should I try to use the P3 1.0 Ghz I have sitting around? I know the Athlon will run a little warmer but with the space i have available I'm thinking I might make a custom "box" with multiple auxillary fans to provide a constant flow through the computer (2 intake fans and maybe 3 exhaust fans in a custom enclosure around the comp, overkill, yes). It will sit in the back and I will run an external DVD drive and monitor towards to front. LCD touchscreen in the dash where the HU and HVAC controls are (move them down) and DVD drive below it.
    So which would you guys recommend? If you guys could be as specific as possible that would be great! Thanks!
    ***If anybody wants to buy a 2.8 P4-M with HT Tech. let me know! I bought it not knowing the difference b/t Pentium M's and P4-M's! Wanted to run a P-M via an Asus adapter and mobo but my nievity got me!
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I'll go with the P3 setup.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    FLAC -zip-'s Avatar
    Ontario/Canada
    What I recommend is test it out first. PIII and a computer monitor , hook up your GPS DVD etc. Run what front end you will go with. Run it and see if you are happy with it, if not run the other system.
    Sound Stage
    Eclipse|MTX|Infinity
    Constant Bitrate WhoIsThisGuy?'s Avatar
    Manchester, UK
    - "Suck it and see" as they say
    M10K, Lilli 7", 512MB, 80Gb HD, slim CD-RW/DVD Combi, nLite Win XP, CentraFuse.
    Planned for years, built for ages, tested for a while, almost installed, never gonna be perfect...
    Dec 2005
    how are you going to move your AC controls? I have a 99 silverado and I can't figure out how to move them. I was thinking about getting some type of rear controls and putting them in the overhead console. let me know what you are doing
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Stick with the Athlon, but underclock it a little to reduce heat.
    Newbie relidl's Avatar
    Jul 2004
    thunderbirds require ALOT of power, you'd be better off with the p3.
    Low Bitrate schpanky's Avatar
    Jul 2005
    My shuttle system with a Mobile AXP 2600+ @ 0.600Ghz consumes only 60W of power, which is enough to run on my car's power point inverter (along with screen and sirius reciever).
    Something to consider
    1995 Ford Mustang Convertible
    DSATX | Shuttle XPC SN41G2Bv2 | 619GL-70NP | CF 1.6 (which is still unusable in the car!)
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    once had a slot style p3 lose its heatsink, 2 month before we noticed.........
    Lez, more widely known as flez1966
  1. Shuttle SK43G & Athlon M?
    By gaki in forum Newbie
    Last Post: 08-29-2005, 03:59 PM
  2. Mobile Athlon XP-M question...
    By migel628 in forum General Hardware Discussion
    Last Post: 08-18-2005, 10:53 PM
  3. Athlon Mobile - speed stepping
    By evandude in forum General MP3Car Discussion
    Last Post: 07-25-2005, 10:27 PM
  4. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
  5. lcd power question
    By jrbless in forum LCD/Display
    Last Post: 04-07-2002, 01:27 PM
