Results 1 to 10 of 19
Thread: Odd Bootup issue
    Nov 2005
    Odd Bootup issue
    Hey guys,
    Here is what I am facing. Right now my Car PC is sitting in my room, and will be installed in the srping most likely due to our cold winters. It is powered via a cig lighter plugged into an AC-DC converter (convertor has a cig outlet). I unplug the PC when not in use.
    When I plug the PC in, the system gets power, and you can hear everything spool up, but nothing on-screen, and no BEEP for POST. I hold down the PWR button to power down, and immediatly hit it again, and boot up resumes.
    This is odd, but doesnt bother me much now. I know this will be bad when I have it in car. In fact, I want a DSSC or uSDC in the future, but dont know how they will react with this situation. The PC is a Cappucino.
    Thanks for any help!
    -John
    Constant Bitrate WhoIsThisGuy?'s Avatar
    Manchester, UK
    Hey
    Check out this post.
    http://www.mp3car.com/vbulletin/show...77&postcount=2
    The issue I had exhibited the same symptoms as u describe (although not mentioned in my post as it wasn't too relevant at the time) as well as a couple of others. Not used a Cappucino (wtf is one? lol) so can't say it is this, but thought it was worth a mention. If u've added any extras inside the unit, try ditching them temporarliy and see if it boots then.
    Good luck.
    M10K, Lilli 7", 512MB, 80Gb HD, slim CD-RW/DVD Combi, nLite Win XP, CentraFuse.
    Planned for years, built for ages, tested for a while, almost installed, never gonna be perfect...
    Nov 2005
    Thanks, I will see if it is a power issue. I am using a battery pack so maybe that is it. For Cappucino Pcs, check out: http://www.cappuccinopc.com/cappuccino.asp .
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    Quote Originally Posted by WhoIsThisGuy?
    Good to know I am not the only one out of the loop.
    They should make the case in the shape of a mug.
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    Manchester, UK
    To be honest, after checking them out, I'm pretty glad I'd never heard of them (no offence meant Slip). Give me my m10k any day
    Nov 2005
    No offence taken... What is wrong with the PC that I have?
    Constant Bitrate pirate_king00's Avatar
    Jan 2005
    ok, the problem is with the 12v feed to the cig adapter. The best bet to run an inverter is use 2-4 guage wire coming off the battery into a distribution block that outputs 4-6 guage (try to stick with 4 guage). Then feed this to your inverter (get an inverter that ties into a switch,so that way the inverter does'nt kill your battery) I bought a monster inverter that has this built into it.
    With that being done you will not have any power issues unless you have an old vehicle with bad alternator or battery.
    Manchester, UK
    Quote Originally Posted by Slippin3
    Not a bad machine but I'm not into pre-built machines in general and the specs on these seem a bit low, eg couldnt see on that website a cappachino with more than 256MB which I find a nightmare in WinXP (admittedly, I only looked at if for like 2 mins)
    Just mho, but whatever peeps are happy with.
    Nov 2005
    Quote Originally Posted by pirate_king00
    Well the vehicle is a 2004 with less than 35000miles, so as good as new. When I am running this it is in my room hooked up to an inverter/booster unit (similar to this: http://www.canadiantire.ca/assortmen...=1134890655260 ) So I dont know if the cig feed is the issue.
    Jan 2005
    Your link did not work for me, however when running an inverter in a car for a computer system, your going to want to do what I recommended on my post to you earlier. The Monster Inverter allows you to run 4-8 guage wire to it. This will allow your pc to get plenty of power (assuming that you purchased the correct wattage inverter). Like I mentioned, I am running a P4 2.8ghz and no problems with my inverter. However I dont have it plugged into cigarette lighter.
    Most wire going to cigarette lighter are 16-18 guage, to thin to carry the power needed for a computer to run.
  1. CF vs HDD Bootup Times
    By Willow in forum Hardware Development
    Last Post: 09-26-2009, 06:47 PM
  2. Odd standby issue
    By tj!2k4 in forum General MP3Car Discussion
    Last Post: 09-21-2005, 05:40 PM
  3. iGuidance Hibernation - Interesting Issue
    By Troy McClure in forum GPS
    Last Post: 06-11-2005, 03:16 AM
  4. Issue with the radio?
    By l0gic in forum Road Runner
    Last Post: 05-07-2005, 05:44 AM
  5. Replies: 13
    Last Post: 01-23-2005, 01:36 AM
