Results 1 to 10 of 12
Thread: HDD mounting
    Oct 2005
    Poland -> Mi, USA
    HDD mounting
    Hello
    I've searched and did not find anything, so I'm asking here.
    I was wondering how to connect a HDD and DVD drive that is going to be mounted in the dash to a computer that is going to be in the trunk?
    I've googled it, been at a local computer store and they did'nt have the cables to do this. Where could I buy such cables?
    Thank's for your help.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Maybe an IDE to USB converter and run a usb cable to the trunk?
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Why would the hdd need to be in the dash?
    You'll need a nice, long USB cable running from the PC in the trunk to a non-powered USB 2.0 hub in the dash (male to female A extension cable). Then you'll need a USB/IDE connector or enclosure for the DVD and a HDD USB enclosure. Both will require vehicle power supplies from RS and short USB 2 cables to connect to the hub.
    I like to use newegg.com:
    Example USB hub
    Example USB cable
    Enclosure for 2.5" HDD (comes with USB cable)
    Some things are harder to find...but MP3Car stocks some good stuff:
    USB/IDE converter/enclosure
    Slim slot DVD drive
    (comes with usb cable)
    I assumed you'd want to go notebook drives for low power etc etc.
    Oct 2005
    Poland -> Mi, USA
    i want the hdd in the dash because it's cold where I live in the winterand I would like to take the hdd out every time I leave the car.
    Can't i use the "ribbons" that are used to attach the HDD to the Motherboard and dvd to motherboard? or it won't work?
    Elsewhere
    The issue is the spec for IDE. It's 18", per the spec. Some have used longer cables with success, however.
    You'd be better off putting the HDD just inside the cabin area with the PC mounted against the back of the rear seat.
    How about the Wiki?
    Jun 2003
    Fairfax, VA
    maybe :
    pip
    pip is offline
    Mar 2004
    Parker, CO
    No, for any distance you really need to go USB...some will surely claim success with long IDE cables but its not the best way to go. Performance may be bad...and may not work at all.
    I would use the enclosure I mentioned (though make sure your m/b can boot from USB). If you cant boot from USB then use a removable HDD device like binary mentioned...but internal:
    Image s of:
    Removable IDE HDD rack
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    or use firewire maybe....?
    In da club....
    ALIZEE WANTS YOU.....
    (\__/)
    (")_(")
    Bunny's first poo
    __ U
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by Dhaark
    Hello
    Searched:
    on usb to IDE cables:
    System Planning...
    USB extension info:
    CarPC Setup Advice...
    discussion on power over usb and hardware options:
    another USB slot dvd thread!
    Good luck and keep reading
    TruckinMP3
    Read the FAQ!
    pip
    pip is offline
    Mar 2004
    Parker, CO
    I like firewire, but firewire enclosures tend to be more expensive & not all PCs have firewire ports.
  1. HDD mounting?
    By DorkVonWaterfal in forum Newbie
    Last Post: 04-04-2005, 12:21 PM
  2. foam-casing for HDD mounting
    By rockthevolvo in forum General Hardware Discussion
    Last Post: 08-24-2004, 02:22 PM
  3. HDD gone bad?
    By VanMan69 in forum General Hardware Discussion
    Last Post: 08-07-2004, 06:55 AM
  4. Linux mounting HDD problem!!!!! Help!!!!
    By lhseong in forum Software & Software Development
    Last Post: 09-28-2003, 12:35 PM
  5. Any great ideas on mounting a HDD?
    By Krash in forum General Hardware Discussion
    Last Post: 11-03-2000, 11:34 AM
