Son an empty case isn't gonna need much power.
I'm going to be connecting a M1-ATX into my Morex 3688 case. As of right now I have 1/0 running from my battery to a fuse holder with a 250A fuse in it. From there, I have 1/0 running straight to my subwoofer amp in my back. What I'm going to do is add a fused distrobution block in the back and have 4 gauge coming from it to my amp and then I have no idea what size I should run to my M1-ATX? Does anyone have any idea? I did a search and came up with 22, 20, 18, and even 16 so I'm kind of lost on what to use.
What does it accept?
Thanks,
Kyle
LoL at billmee. Thanks DarquePervert. My ground would be the same size as well correct?
Anyone?
Depending on the distance you have to run the wire I would say for up to 10 feet use 14 or 16 gauge. 8 gauge is pushing it. the m1atx can only pull around 10 amps and 14 gauge can easily handle that 8 gauge can handle up to 60 amps.
always good to have the ground wire of the same gaugeOriginally Posted by kbkid
