Results 1 to 4 of 4
Thread: clarification on video signals
    Newbie nozila's Avatar
    Sep 2005
    Australia
    hi everyone,
    im obviously new to this, have been reading the forums for a while prior to signing up. anywho, can someone tell me if all that is required to recieve visual and audio signal from the screen is the rca audio/video input and output. reason why i ask is that the computer that i currently have at the moment doesnt have rca video/audio output. does this mean that i need to purchase a video capture card in order to get signals from the computer to the monitor? or is there an adapter in which converts vga from the computers video card to rca signals. im confused atm as to how it works. in addition to this, im not sure but will rca produce excellent video quality as oppossed to the vga input that a computer's video card requires.
    furthermore, there are some screen in particular touchscreen's which has vga output, im assuming this is for the touchscreen function to work? or is it for plugging into the video card?
    puzzled member.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You ARE puzzled. First, the computer doesn't receive either visual OR audio signals from the screen.
    Second, displaying computer output on a video screen results in terrible output.
    Third, what you really need is a VGA screen like Lilliput or Xenarc or Linitx. Those screens can accept the VGA output from your computer.
    Check the FAQ Emporium for a thread on VGA vs. Video.
    Want to:
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    Quote Originally Posted by nozila
    puzzled member.
    The touchscreen VGA monitors that you find use USB for the touchscreen and VGA for the video.
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    Elsewhere
    hi everyone,
    puzzled member.
    1) Some capitalization and punctuation go a long way toward having your posts readable and understandable. Seriously, this post was a headache to read. As a result, fewer people are willing to help you.
    2) Yes, there is an adapter to convert a VGA signal to RCA composite video. It's called a scan converter. Be aware that it will reduce the quality of your VGA output significantly. Most users that take this route are unhappy with the clarity of the PC display.
    3) PC's aren't designed to display on a TV, period. Even if you have a video card with native TV-out (such as on the EPIA M10000 motherboard), it will still look blurry. Some tweaking can get the display to be usable, for the most part, but the ideal setup is to use a display with VGA input.
    4) No screen has anything OUT (unless it's a complete headunit which would have speaker out, pre-amp outs, etc.). They only have signal IN. AS buurin stated, VGA is for the PC display. USB is for touchscreen funtionality. If the display is not a touchscreen, there would be no USB, obviously.
    How about the Wiki?
  1. Trouble with PCI video card install ... help!!!
    By DonkeyBoy in forum General Hardware Discussion
    Last Post: 08-10-2005, 05:22 PM
  2. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 01:00 AM
  3. onboard video vs a video card, power and cpu usage
    By stapan in forum General Hardware Discussion
    Last Post: 06-09-2005, 03:43 PM
  4. Extreme video playback choppyness with HVAC software
    By Dexter in forum Software & Software Development
    Last Post: 04-11-2005, 02:24 AM
  5. Media Car video player
    By MatrixPC in forum MediaCar
    Last Post: 03-22-2004, 01:33 PM
