The wire that came with the kit was probably 8 gauge wire, remember smaller the gauge number the thicker the wire.
If you going to be using a distro block like you said then I would suggest you use 4 gauge wire from the battery to the distro block. And from the distro block use 10 gauge wire to connect to the opus and probably 8 gauge wire for the amp (this will depend on the amp, look at your manual it will tell you what wire size to use).
LinkBack URL
About LinkBacks
