Results 1 to 10 of 13
Thread: BMW iBus Users needed!
    Nov 2005
    I just recieved my ibus from Rolfe and am trying to figure out how to connect it to the cd changer. The cd changer plug has three ports while the ibus has 4 prongs. What goes where?!? Please help!
    Jan 2006
    Hi Stevo759
    I just joned this forum,
    There are 4 pins on the interface:
    +12V: (any 12V source switched or unswitched) you can get hold of.
    GND: and Ground in the car
    IBUS: the Ibus line itself. there are several locations you can get hold of the IBUS line, In US-Models there's usually a pre-wired CD-Changer cable in the trunk, if you want to mount it there...
    NTSC: This is for enabling the Rear View Camera Input n the Nav Unit (Pin 17 on the Nav unit) IF YOU HAVE A SOFTWARE LIKE CARMES etc that enables that switch.
    Rolf
    Mar 2001
    Baton Rouge, LA
    Hey Stevo,
    It's been a few months, but I believe this is how it's plugged in.
    On your IBUS interface, the pins are marked with IBUS ->+12V -> GND. The CD changer cable has 3 wires.. I believe the brown wire is your GND, the white w/stripe is your IBUS.
    If you want to confirm, you can hook up a voltmeter and check the voltages. The IBUS line should read +12V and fluctuate when it's sending messages. The +12V will stay +12V.
    2006 Nissan Titan LE Truckputer
    [I]No installation thread yet[/I
    2002 BMW 330Ci Steel Grey Metallic *Sold!*
    Installation Thread
    Nov 2005
    Quote Originally Posted by immortal
    Hey Stevo,
    Thanks immortal...so if i dont have a NTSC...then the last pin on the ibus shouldnt be connected to anything right?
    Mar 2001
    Baton Rouge, LA
    right.. just use the 3 you need
    got any pics of your install yet?
    Installation Thread
    Jan 2005
    All the BMW guys, anyone care to advise me on how the software setup of the ibus is done from start to finish? Also does anyone have the bmw skin with the day and night set up?
    leo
    Jan 2005
    Also, how did you guys run sound to the stock amp?
    Nov 2005
    pics are up in the showroom
    I used the SVEN4 to go to the stock amp
    Newbie Onagrote's Avatar
    Dec 2004
    There is some documentation on how to connect it at http://www.eedesignkits.com, but it is for the USB IBUS interface instead of the serial port one. Take a look at it, it might be helpful...
    Jan 2005
    Can you get the distances detected by the parking sensors through ibus?
  1. BMW IBus control for Centrafuse?
    By Hark in forum Centrafuse
    Last Post: 12-27-2008, 02:04 PM
  2. BMW 540 Touchscreen Complete!
    By sajid753 in forum Show off your project
    Last Post: 04-23-2007, 05:52 AM
  3. Replies: 96
    Last Post: 11-30-2006, 08:16 PM
  4. 03 BMW 330i Dinan S3 Project
    By fattytl in forum Show off your project
    Last Post: 09-27-2005, 11:24 PM
  5. Girder Users... help needed.
    By mick-uk in forum Operating System Optimization
    Last Post: 01-04-2005, 02:30 PM
