Results 1 to 10 of 11
Thread: Big dash and alot of options, what to do?
    Jan 2006
    I have a 2001 toyota Highlander. It has a nice area on the dash. I looked into buying a Pioneer In-dash GPS system (avic-n2). But its a lot of money. Then I came across this site for the first time yesterday, which is great! I happen to have a laptop to use, and was looking into different LCD's to buy. I also learned about and downloaded Media Car v1.90. So from my understanding Im half way there. What I wanted to get was feed back from the pro's about some things. I want to try and keep it simple for the most part, being it will be my first of many projects. The wiring alone will take me forever.
    -I have a factory radio installed in a 8"x4" slot. Is there an lcd display that will fit that easily, or will I have to learn how to use a dremel?
    -How do I get a radio if I am basically using a computer? Will I need an Aditional DIN-1 slot for a radio?
    Joe
    Dec 2005
    well depending on the brand and quality by saying you get a 8" the dimensions are probably going to be around if not (W206 mm H150mm 28mm) so your going to have to learn how to use a dremel and a few other things.
    Jan 2006
    I wanted to add a picture of the Dash im working with. I thought of removing the radio, and using the Xenarc 7"IDT to take up 1-din and then having a normal car stereo take up the other 1-din.
    My concerns are that the xenarc will block the AC controls when it opens up and extends upward. I would really like a screen that will just fit the 8"x4" radio slot. (as shown in the pic)
    What I need to know is;
    where will a radio go? (will the pc house a radio?)
    will I have to custom make a dash?
    should I just go with the Xenarc7"IDT and radio combo?
    Am I missing anthing?
    -Joe
    Sep 2005
    iowa
    you can get FM tuner cards pretty cheap for pc, dunno about laptop.
    Feb 2005
    West Valley City, Utah
    usb tv tuner card with fm.
    Progress,.... that is what I keep forgetting ;)
    planning_[++++++++++]. 110%
    parts___[++++++----] around 60%
    install___[-----------] -9,000%
    was Boston -> now Canada!
    Cool I have a 2002 Highlander but you don't want my setup unless you spend the next month of your life stuck in a workshop and know how to program assembly language and built electronic circuits
    edit....I posted this a few months back of what I did to my dash bezel.
    I built this for my SUV.
    This is the face of it.
    Face
    The screen is driven by a 12V motor. I build the whole thing from scratch and it's driven by an 8051 microcontroller. I build the circuit to drive the screen and I have a bypass switch as well. The bypass switch has a manual and auto mode and if I am to park in a parking lot someplace I simply select auto and when I shut the vehicle off it will automatically close.
    Screen Driver
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    hey chuck, what does you door consist of?
    cool project, BTW
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Bought a textured piece of 12" x 12" ABS plastic through You-Do-It Electronics in Needham MA.
    I used a guillotine cutter to cut 3/16" strips. The length of the door slips my mind but it needs to be long enough for the drive bolt to catch on to it.
    I bought sticky back felt from a local craft store hoping it would hold the door together...I applied the felt to the strips and put heavy weight on it for a couple days. It has worked great so far any how.
    Chuck
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by chuckster
    Chuck
    Another decent source of abs is on amazon, partsexpress sells 24" x 12" for $4 - $8 depending on the thickness.
    Jan 2006
    Chuck, Cool project, I read about it in another thread. I wasnt thinking of getting so involved. ( I dont trust myself ) What I did want to try was getting a motorized 1din LCD unit installed and then use the other din for a stereo. (The radio slot is double din right?) I should be able to handle a project like that. Or what I really want is a simple LCD that will fit right in to the radio's slot, and wire that to a laptop. But Im not sure how the stereo would work. My understanding is, you have a computer, then a stereo. Im not sure If I would want the older laptop I have to handle a stereo. My most important goal is to try and stay away from fabrication. At least for this project. I want to learn that for the future.
    Joe
  1. Made fiberglass dash but looks like crap! PLZ HELP!
    By XxAndyxX in forum Fabrication
    Last Post: 08-24-2006, 11:50 AM
  2. painting a dashboard
    By EsKALad in forum Fabrication
    Last Post: 09-14-2005, 11:25 PM
  3. Housing size of digitalww in dash
    By leenas in forum LCD/Display
    Last Post: 07-27-2003, 06:21 PM
