welcome Stefani.
Good luck.
Hi all,
Just wanna send greetz to all.
Been browsing the forum for a while now
The questions will be coming soon, I'm sure ...![]()
Gwen
welcome Stefani.
Good luck.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
how original...Originally Posted by Quattro
how about:
Congresswoman Gwen Moore, Representing Wisconsin's 4th Distict
Post Whore's tip:
User CP-> Edit Options-> Number of Posts to Show Per Page-> 100
http://www.frappr.com/mp3car from this thread http://www.mp3car.com/vbulletin/general-mp3car-discussion/65044-frappr.html
ODYSSEY
All information expressed in this post is my opinion, and should not be regarded as a statement of fact.Digital-Car UK|
(\__/)
(")_(")
I was more thing "There's nothing going on but the rent"
GUTHRIE
One thing you didn't mention is the CPU.
CPU is vitally important because that's a huge factor in how much power teh system draws.
The PSU you specified (PW-200M) does not provide regulated 12v. So as your car's power output fluctuates (typically between 10v and 18v), so will the power to the motherboard. I the power drops below a certain point, the motherboard sill shut off or the system will crash. If the power is too high, you'll fry your motherboard and/or CPU. In order to have this PSU work with a vehicle PC, you need a voltage regulator, like the Carnetix units that are available in the mp3car.com store.
Personally, i'd go with an all-in-one solution like the M-series or an Opus model. They regulate the 12v rail, have battery protection, a startup/shutdown controller and other features as well. The issue with those units is spec'ing a system to fit with in the power constraints of DC-DC PSUs.
You are looking at a 1.8" HDD. Nothing wrong with that, but you can save a few bucks by going with a 2.5" HDD of the same capacity.
Can get one up to 3Ghz, dono yet.
Was only thinking of weight gain. What's the pro's & con's between 1,8 & 2,5?
cheers
Originally Posted by Gwen
Are you anorexic or something? weight difference between a 1.8 and a 2.5.
2.5's hardly weigh anything as it is. Not worth the cost to save a small bit of weight.![]()
