Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: Q: Help me out with power suply.
    Sep 2005
    helo, I have decided to power up my carpc with a AC-DC power suply for also using it into my house.
    Does a Shuttle SilentX 250W PSU works on my PCCHIPS m789CG mobo?
    And then, I have found a DC(12v)-AC(230v) inverter with following specs:
    input: 12Vdc(10-15)
    output: 230Vac
    Max power: 300W
    Usage: 400mA
    Will this say I can MAX use 400mA with this:s
    THX!
    Elsewhere
    The Shuttle power supply is ATX-compliant. So is the motherboard. Yes, it will work.
    How about the Wiki?
    Sep 2005
    This is it...
    1) And do I have to put any fuses in there?
    2) And isn't it wrong that on my inverter stands MAX 400mA?
    Thx
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    yes you must use a fuse. and do not even think about using the lighter socket for power!!!!! Go read the FAQs on how to wire an inverter or PSU.
    As for the 400mA - seems like you only have a 100W continuous inverter. post more details.
    Sep 2005
    And if i want to do it via sigarette-lighter, is a dc-dc better? it must go via siga-lighter...
    Mar 2004
    Bristol
    NO!
    you cannot use the cigarette lighter. it is not safe.
    oh and that pic is both huge and useless. ytou need to show the sticker on the back with the specs.
    Sep 2005
    http://www.rockingstone.nl/itcenter/...bcat=Voedingen
    this are the specs... in dutch How can I make it work on siga-lighter?
    Mar 2004
    Bristol
    Quote Originally Posted by tweakroxor
    how can you make it work? only run about 100W off it - max! iven then you will be pushing it for constant use.
    do yourself a favour and go about why people use dedicated wiring.
    not only will it be safer but more efficient and cause you less problems such as the inverter not getting enough power.
    Mar 2004
    Bristol
    i am off home now. I am sure Darquepervert will be more than happy to explain further if you pm him.
    Sep 2005
    should it be better use a DC-DC power suply? It HAS to go via siga-lighter..
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. What Power Suply?
    By cableguy in forum Power Supplies
    Last Post: 10-27-2005, 02:38 PM
  3. Low power alarm, kind of
    By System-f in forum Power Supplies
    Last Post: 03-11-2005, 01:48 PM
  4. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  5. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
