Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Ok I'm ready to go - Please advice :)
    Jan 2006
    After reading this forum and clicked every link available to resources i got VERY VERY excited about building my own CarPc.
    A lot of guys (maybe girl) here are pro's so advice is much appriciated
    My Setup
    Monitor
    Lilliput 7" LCD Monitor Touchscreen VGA
    Motherboard
    ASUS P4T533-C
    Processor
    Pentium 4 2.53mhz
    Memory
    512mb
    Souncard
    Onboard
    Graphicscard
    G-Force2 64mb
    Network
    Linksys Wireless Lan
    Harddisk
    80 GB Western Digital 3.5"
    Keyboard/Mouse
    Other
    Normal 350 watts Powersupply
    CD/DVD Drive
    Power Converter 12volt -> 230 volts
    Belkin AC Anywhere™ 300W
    Audio
    Headunit
    Sony Something
    2 x 4 ch Amplifiers 1300w each (2600w RMS)
    Front Speakers : Composet from MB QUART
    Middle of the car (doors) : Composet from MB QUART
    Rear Speakers : Composet from MB QUART
    Trunk Speakers : 2 x 12" Rockfort Fosgate woofers
    My Car
    Volkswagen Golf mk4 (5 doors)
    All audio hardware is already connected and working.
    Is this setup ok (PC) and do i have to think about special things i maybe forgot ?
    Thanx in advance
    Oct 2004
    NY
    p4 will be way to hot & power hungry & inefficent.... rethink your approach....
    Jan 2006
    Quote Originally Posted by turbocad6
    Why to hot ?
    I have 2 big tranparent fans for the case and heatsink with fan for the cpu
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Welcome to the forum bro...you've come to the right place. There is a lot of knowledge on this forum and the people here definitely know what they're talking about...(Turbo is definitely one of them).
    Turbo is right about the p4...if you havn't gotten your parts yet, than i suggest getting a lower powered motherboard. It will ultimately save you the trouble of feeding it enough power. I also suggest getting a better power supply. Since the computer will be built into your car and hardly ever removed, you want to hard wire a power supply that includes a startup/shutdown controller. These power supplies are designed specifically for putting computers in cars....i say that it would be a shame not to use one.
    Are you running 3 sets of mb quart's? Do you have any pics? I bet it gets loud...
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Elsewhere
    You're putting alot of money into audio equipment as well. That indicates to me you want this whole setup to sound good.
    An inverter is very likely to screw all that up with RF interference, causing all sorts of ugly sound. A DC-DC power supply will reduce that possibility significantly.
    However, your P4 setup will draw 59.3 or 61.5 watss, depending on which version of the chip. There are a couple DC-DC power supplies that will provide the power you need, but you're still likely to go over that limit with the other 12v devices (HDD, fans, screen possibly). If this is the setup you're determined to use, I'd check out the DSATX DC-DC PSU. It's your best bet, but still no guarantee it'll work.
    Then there's the inefficiency of the inverter. An inverter's job is to convert DC power into AC power. Then the comptuers PSU will conver the AC power from the inverter back to DC power for the comptuer to use. What a waste.
    You say you've clicked on every resource and link available.
    Here's another one for you that I don't think you've checked out:
    mp3car.com FAQ Emporium
    If you'd have checked that out, you'd know why we're suggesting you rethink the system you've got planned.
    How about the Wiki?
    Jan 2006
    Thanx for the info 3onDubs
    My idea with the power is as follows..
    De powercable from the battery (50mm2 thick) will be connected directly to the Belkin powersupply and all other electronic devices. On my dash i have a powerswitch from Caliber that removes ALL power from the battery to the whole circuit in the car. You see this switch on racecars a lot.
    Next to this switch i've already made two original computerswitches. 1 for the pc power on/off and one for softreset.
    So when i start my car i will turn the MAIN powerswitch on (to power the radio, amplifiers, Belkin powerconverter etc etc) and then i will press the button to switch on my pc.
    I already have all the parts. So for now it's a waste of money to buy a new mainboard and processor
    What's the worst that can happen ?
    (Btw every cable is secured with gold Caliber fuses)
    Jan 2006
    Not yet. Will make pictures when i'm done.
    The DSATX DC-DC PSU look great.
    Does that mean i don't need any powersupply for the pc. Does this thing do it all ?
    Ow i forgot Installed 2 Powercaps to have constantly 12 volts
    Oct 2004
    NY
    the worse that can happen is after you get it all installed & realize what were talking about & why, you'll either wind up ripping it out & re-doing it, or live with a system that's not so hot.... well, actually it'll be kinda hot...., but not that great.....
    putting a p4 in your car is like putting a big block chevy in a honda..... while it can be done, it will not be the most effective or practical install & will create other problems.... you'd be much better served by turbocharging a light wieght engine in that situation..... don't matter if you already have a bigblock sitting there.... it's still not good.......
    Jan 2006
    So you suggest a pentium 3 ? (as i watch @ my empty bankaccount)
    BTW Thanx for this great help guys
    Super Moderator xBrady's Avatar
    USA
    If you have the chip already just underclock it (if your mb lets you). Definitely get a DC PSU rather than the inverter though. If you get a 150W opus and underclock your CPU a bit I'm sure you'd be pretty well off.
    Installed.
    -GPSSecure- - GPS Tracking
  1. Small Car, budget complete setup advice
    By Scouse Monkey in forum Car Audio
    Last Post: 07-14-2010, 12:17 AM
  2. case advice needed
    By michfull in forum Newbie
    Last Post: 12-19-2005, 10:56 PM
  3. need advice on system type - ITX or ATX
    By craigj in forum Newbie
    Last Post: 09-18-2005, 11:03 PM
  4. Before I lay cables, here is my USB device layout. Advice?
    By Bailey in forum General Hardware Discussion
    Last Post: 03-13-2005, 10:03 AM
  5. Can someone offer some advice on a good LCD
    By gordie08 in forum General Hardware Discussion
    Last Post: 06-28-2000, 10:32 PM
