Results 1 to 10 of 13
Thread: I think I am making this more difficult...
    Jan 2006
    Hi all new member, but have been researching for months...
    Quick break down:
    I have a laptop that will be installed with a docking station. Installing that and getting power to that I understand, finally.
    From that is what I get confused about. I want to run GPS, Internet and Windows for starters.
    The confusion starts:
    1. Do I trash my stock head unit?
    2. If I do, how to I get am/fm/satellite and cd play back?
    3. How do I pull sound from the audio out of the docking station to amps? I have one amp powering my sub and 1 powering my speakers.
    I think the rest I understand from someones diagram.
    Thanks and sorry for the super noob questions.
    Constant Bitrate RawsonDR's Avatar
    Dec 2005
    Dayton, OH
    Whether or not you keep your headunit is completely up to you. If it supports an auxiliary input, plug your laptop into that.
    You 'pull sound' out of your laptop the same way you pull sound out of any device. You plug something into it. Your laptop has an audio output; your amps have an audio input. Connect the two.
    This much is at least covered in the FAQ section.
    Jan 2006
    My amp is connected by rca from the radio. Then amp rca out to the other amp rca in. Kinda like a daisy chain.
    I don't see how my factory headunit would accept a 1/8 plug. Maybe that is something an aftermarket deck has...???
    I'ma read'n, I'ma read'n...
    Jan 2006
    Ok, please tell me if I am on the right track with this:
    1. from laptop to aux in on headunit
    2. rca out of headunit to amps
    3. etc...
    I thnk I understand this correctly from the diagrams in the FAQ area...
    Elsewhere
    You're correct.
    How about the Wiki?
    Jan 2006
    This diagram si what I am thinking:
    Maximum Bitrate riddle14's Avatar
    Aug 2003
    TN
    you are right again. however if you want good clear video then you are going to want a VGA monitor and not an RCA screen.
    "I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I know so!!!!" Now I'm here!!
    By "ToneRiddle"
    Jan 2006
    Oh, ok. I was thinking that the flip up dvd headunit would offer like, s-video or something.
    Dec 2005
    Dayton, OH
    Quote Originally Posted by eggie
    I imagine this would depend heavily on the unit. Since we're still only talking in hypotheticals, anything is possible.
    Same with your audio question. Your diagram is correct only if your headunit has an auxiliary input. If it doesn't, you'll have to either use an fm modulator (plugs into antenna jack on radio), fm transmitter (wireless), or plug straight into your amp from the laptop (but then what about your radio?).
    Elsewhere
    SVideo signals from a PC aren't going to be much (if any) better than an RCA composite signal from a PC.
    Thise screens are designed to display TV or video game signals which are a substantually lower resolution than a PC's video signal.
    The other thing is that you're going to need special hardware for the PC to display the TV signal. Some laptops have this built-in. Some don't. Check yours, if you haven't already.
    How about the Wiki?
  1. Making large reflector
    By peapea in forum Fabrication
    Last Post: 01-10-2006, 09:25 PM
  2. Making a mold after dash customize ??
    By Don 944 LA in forum Fabrication
    Last Post: 11-06-2004, 04:41 PM
  3. Something wrong, help need! : making -8V and 5V PS,
    By helloman in forum Power Supplies
    Last Post: 09-06-2004, 05:08 PM
  4. MediaEngine Skin making
    By liquid_smoke in forum ME Archive
    Last Post: 09-13-2003, 09:45 PM
  5. custom dash making....
    By ifnh573 in forum General MP3Car Discussion
    Last Post: 10-13-2001, 01:39 AM
