Results 1 to 8 of 8
Thread: case fan
    Low Bitrate LVExpo's Avatar
    Oct 2005
    Las Vegas
    Question case fan
    should i install xtra fan, beside the one that came with the ampie case??
    i use m10k with 512 and m2-atx and going for 80gb.
    thx
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Why NOT?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Mar 2005
    NYC
    did you get your monitor and gps yet?
    Oct 2005
    Las Vegas
    no, get the monitor soon and gps a littl later. think its better to install another fan?
    if i install a second fan, should this one blow air out of the case or should it blow air in the case? the one thats already there (in the middle) is blowing air out.
    thx
    Variable Bitrate DaveB's Avatar
    Mar 2004
    I'm installng one 80MM fan in my homemade case and it will blow air out.
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    Oct 2005
    Las Vegas
    circulation
    so u don't need air in and out to get circulation...u just need to blow the air out of the case???
    so every time i am installing something that gets warm in a box/case and needs to be "cooled", i just install fans, that "takes the warm air away", instead of bringing "fresh" air in, to "push" the warm air to the "blow out fan", to get the circulation?
    hope u know what i am talking about
    Elsewhere
    In a normal desktop-style case, you want two fans (at least) to pull fresh air in from the front and blow it out the back. In an ATX system, the heat builds up right around the CPU, which generates the most heat. So there's usually an exhaust fan right there, to pull that hot air out of the case.
    In a smaller case like the Ampie, there's not a lot of room, so you're going to want a fan to draw air out more than you want one to pull fresh air in.
    How about the Wiki?
    Mar 2004
    I'm putting a 32CFM fan in the lid of my box. Elsewhere, the box will have ventilation holes. It will draw cool air in through the vent holes and pull the warm air out through the lid. I could just as well have turned the fan around and pushed air out of the vent holes.
    It doesn't matter which way the air goes as long as you moving air through the box.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
  1. Ampie - ITX CASE for sale
    By JRunner in forum Classified Archive
    Last Post: 08-18-2005, 12:40 AM
  2. LED Fan
    By EBFoxbat in forum General MP3Car Discussion
    Last Post: 11-11-2004, 04:46 AM
  3. is frodo compatible with voice software?
    By nappyjim in forum FrodoPlayer
    Last Post: 11-01-2004, 05:50 PM
  4. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 10:42 PM
  5. Mounting the case
    By TheFly in forum General Hardware Discussion
    Last Post: 05-05-2002, 04:11 PM
