Keep in mind even if the space is double din, chances are they dont make a double din installation kit for your vehicle (meaning that an installation kit exists for installing an aftermarket head unit, but not both a head unit and lcd) and therefore you are left with the task of mounting both units in the dash somehow.
I have a ford focus with a double din and had this problem. Ended up paying best buy $120 to install the head unit and lcd and it doesnt look very good. in fact i am bringing it back because the lcd is slowly creeping its way into the back of my dash! They took the normal single din installation kit and modified it and had the two headunits just sitting on top of each other.
I had it done about a month ago... my plan is to walk in there and be like "look what my installer did!"... because the install looks crappy, the install kit if cracked on the sides from the mod. They used a black marker to cover up exposed metal casing from the head unit and lcd. and the lcd sits back pretty far, by no means flush with the dash. Then once they are like "you shoulda let the pros do it" i'll drop the bomb that they did do it
Way to get off topic... so yeh anyways chances are the stuff will fit but its not "plug n play" however it is doable.
LinkBack URL
About LinkBacks
