Results 1 to 3 of 3
Thread: 18 Awg
    Low Bitrate LVExpo's Avatar
    Oct 2005
    Las Vegas
    Question 18 Awg
    is 18 gauge "thick" enough to power my computer from the dash to under the seat (maybe around 6ft)?
    i would use a "thicker" cable, but the ampie case comes already with the connector, so i just extend the wires with another 18 gauge wire to the prober length, right? or is it better to extend with 16 or 14 gauge? u should always use the same gauge!!??
    i use m10k with m2-atx, soon with xenarc tsv, gps.........
    thanks again for help!
    Variable Bitrate Freelander's Avatar
    Jul 2005
    NYC
    wow, you are a question posting machine
    there has been a lot of discussion regarding wire size, and most people don't agree. this is one of the better threads. get your read on
    http://www.mp3car.com/vbulletin/show...727#post716727
    Low Bitrate grimor2000's Avatar
    Dec 2005
    Chicago-ish
    you can use thicker wire, I would go with 16 gauge so there will be less resistance and current lost in the line.
    Causa latet vis est notissima
    VIA SP13000
    1GB DDR400
    Slimline Slot-load DVD-RW
    60GB 2.5 Inch SATA 5400RPM
    Dual Active PCI riser
    PCI TV/FM card
    Logisys FP800
    Thermaltake VFD Media Lab
    M1-ATX
  1. Power/Fuse Rundown, help if you can!
    By CavityCr33p in forum Power Supplies
    Last Post: 07-14-2005, 01:41 PM
  2. At last: AWG to mm Table
    By Cris in forum General MP3Car Discussion
    Last Post: 09-06-2004, 06:58 PM
  3. WTB: (or trade) 8" 18 bit touchscreen
    By SuperMatty in forum Classified Archive
    Last Post: 04-11-2003, 12:08 PM
  4. Does 18 conductor printer cable work for LCDs?
    By LESLIEx317537 in forum LCD/Display
    Last Post: 02-11-2002, 12:03 PM
  5. help please how much mm is 22 awg & 18 AWG
    By marsjell in forum Power Supplies
    Last Post: 10-05-2001, 09:02 AM
