Results 1 to 10 of 15
Thread: fuse the pc?
    Low Bitrate LVExpo's Avatar
    Oct 2005
    Las Vegas
    fuse the pc?
    should i fuse the pc? the m2-atx comes with a 15A fuse, is that enough "fused"?
    Elsewhere
    Put a fuse close to the battery, as well. You'll be fine.
    How about the Wiki?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Also, fuse the other hot wire too (the ACC/IGN wire). 1A or 3A fuse should be good on this wire.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Oct 2005
    Las Vegas
    can i do this?:
    an 8 gauge wire with a fuse near the battery to a barrier terminal strip (c picture!!) under my dash and from there with an 18 gauge wire (like the one that comes already with the ampie case) to the case/m2-atx????
    if i want to use a thicker cable, i have to change the whole connector on the case. if its not a good idea, to use 18AWG, then why does the ampie case comes with 18AWG?
    like i said, we talking about 6ft (from dash to the passenger seat).
    i am really sorry to bather with all those questions, but i really wanna do everything right. don't wanna risk any fire or brake expensive computer parts!
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    Quote Originally Posted by LVExpo
    from my understanding the purpose of the fuse near the battery is to protect the wire whereas the fuse on the m2-atx protects the PSU
    Without a fuse near the battery:
    Imagine your power wire got shorted somewhere inside the car. A whole lotta current is going to run from the battery to wherever it is shorted inside the car which leaves you with like 8 feet of wire being heated up and ready to start a fire. Even if/when the m2 fuse blew, the battery is still being shorted because the short is BEFORE the m2 fuse.
    However with the fuse near the battery, when it blows it essentially disconnects the battery from the short, assuming the short is not before the fuse, which is why you want to keep the fuse as close as possible to the battery.
    Hope that helps.
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    Oct 2005
    Las Vegas
    sorry, but it does not help. i have a fuse next to the battery, but do i have to use a fuse between the barrier terminal strip end the computer case? i think not, but i wanna make sure!
    my biggest problem right now is: is the 18 gauge wire that came with my case (ampie/voom) thick enough to power the computer?
    i also think about running an 1 gauge (the thickest possible) back in the trunk to a nice, fused distribution block and from there to the computer, the amps and maybe my power inverter that i will use (if i will use it) for show stuff like a fog machine. but it still leaves the same question: IS THE 18 GAUGE WIRE THICK ENOUGH??? probably 6ft of 18 gauge wire from computer to battery/distro block and IGN to ACC or dome light. and of course the ground somewhere at the right spot
    is there nobody who got pictures how there installed there powering??
    hopefully somebody can help me!
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    It depends on how much current the computer pulls. Keep in mind most of the wiring in the car is 16/18 gauge and some of those circuits pull 10-15 amps.
    If that wire came with the case that'd designed to hold the computer, it'll be fine.
    You still want to have a fuse between the barrier strip and the case in case something in the computer shorts out.
    1) So you don't have to replace the larger fuse up front
    2) the smaller wire would probably melt and cause a fire before the large fuse at the battery ever blew.
    I think the formula for fusing is get a fuse that's draw + 10% or something like that.
    Oct 2005
    Las Vegas
    i thought the same thing, that, when it comes with the case, it should be fine. guess i just wanted to hear that from another person.
    i will figure it out somehow.
    the remote wire from an radio to an amp is always very thin, so the ign cable that goes from the ignition to the computer can be thin also right?
    Sep 2005
    Seattle, WA
    okay i think i get you... i was concerned about this also...
    what i was ultimately told is that since you only have about a foot of 18g it is fine... the explanation being that the voltage drop(loss) across the 18g piece of wire will be so small(due to the wires length) that it will not generate enough heat to worry about.
    B Smoov
    Sep 2005
    Seattle, WA
    and why in the world would you put a fog machine in your car?
    why not put something useful like a foam or bubble machine...
    c'mon use your head
    jk
    B Smoov
  1. ONINE PETITION: TomTom Navigator for PC
    By bLindmOnkey in forum GPS
    Last Post: 06-07-2007, 02:16 PM
  2. Lil' tutorial for newbies
    By Jamiks in forum Newbie
    Last Post: 05-25-2007, 02:18 PM
  3. Replies: 21
    Last Post: 07-22-2005, 02:35 PM
  4. PC / Vehicle interface
    By bluelip in forum General Hardware Discussion
    Last Post: 07-15-2005, 02:24 PM
  5. Inverter not booting pc after second try
    By ChrisC in forum Power Supplies
    Last Post: 11-12-2004, 11:51 PM
