Most screens will return to a preset location, but the unit wiring must be correct (pay attention to which wire must be switched, which is constant, and which is ground). You may have to "run" the screen once to get the correct angle to avoid the ridge, but once that is done, you should be o.k.Originally Posted by EricE
To answer your question, No, the unit won't stop when it encounters resistance.
Michael
LinkBack URL
About LinkBacks
