Results 11 to 20 of 23
Thread: BMW E39 carpc questions (Europe)
  1. #11
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Cris
    I meant when will StevieG's access control be a part of your skin...
    It won't.
    The Access control is supposed to run first and then start up your frontend when access is granted.
    You can skin it (I have used the OSK that was in the orginal iDrive by BTBE) to look similar to the skin for a front end if you want. I use the iDrive empty with the OSK.
  2. #12
    Newbie WaterLift's Avatar
    Feb 2006
    Belgium/Aalst
    Thumbs up
    First of all, thanks everybody for the quick replies.
    The truth is none of them really do work 100% perfectly, especially if you stuff them with all the aditional software you have in mind...
    Hmm pity, is there a general consensus on what the most versatile frontend is?
    - there are quite a few navigation programs that cam be succefully embeded into a front end, like Destinatot, IG, et. Depends on where you're from and what nav software you are going to use. Same thing for Radar feature.
    - I think all front ends support Phoco. Check for your phone's compatibility.
    - iBus is not for car diagnostics. For that you must have a OBD II scanner&software. iBus is for controlling stuff already in the car. Almost every BMW install has that.
    - an AV camera is usually used for a rear view camera. So this is not something to be supported from a front end. However you can have an USB rear view cam, but it's not by far the idea solution.
    - video - obviuosly. TV - with a TV card. DVB, you can buy a separate kit, that pluggs into the AV from the monitor. It's a stand alone kit.
    - TS. 8" will not fit in that dash for sure.
    - access control. There's a little program by Stevieg that's made for Centrafuse.
    - that's almost doable. It won't be the same...
    -Is anyone using the radar and/or TMC feature in Belgium?
    -Checked phoco, doesn't support it yet but maybe soon
    -Thanks for clearing that up with OBD/iBus difference
    -I'll just wire the cam to switch on when I go into reverse, you're right no need for frontend here
    -Dumped the idea for an 8" TS, went and checked with the local stereoshop and missed 4mm in height
    -Access control looks ok, hope I can reskin it into a bmw style panel
    - Maybe the dealer has a dummy iDrive set that I can use to create that kind of button.
    There's no front end that will satisfy all your demands by itself.
    OK fair enough it's a bit demanding , got any suggestions on what could come close?
    You could use the RAM, HDD, WiFi, USB stuff...the rest they're a little too much for any PSU to take on. Not to mention all the stuff you want to add...
    Maybe it's best that I sell the pc and just start clean xcept for the usb stuff, with that kinda amp draw my battery wouldn't last too long when I'm not driving.
    As I said, as far as I know, an 8" will not fit in there.
    You can always add the buttons, but I'm sure it won't look as good as it does made by them.
    True again ;-) Went to my local car hifi centre and tried a WS 8" and no joy missed only a few mm of space dang
    Again thanks m8
  3. #13
    Feb 2006
    Belgium/Aalst
    Thumbs up
    Hi Darque,
    I decided to ditch the ATX pc and go for a new ITX setup, you're right it's simply too big to be "integrated" and the power draw is murderous
    Thanks 4 the reply
    Quote Originally Posted by DarquePervert
    You could use the PC itself, although I'd ditch the high-end 3D card. There's no need for that in a car at all and it will just suck up precious power.
    The only reason you wouldn't want to use that setup is simply size and power requirements. The power requirements can easily be handled by using an inverter (not recomended, at least by myself) or reading this FAQ and choosing an appropriate DC-DC PSU.
  4. #14
    Feb 2006
    Belgium/Aalst
    Lightbulb
    Ah sweet just saw it *drooling*
    Is the "climate" button for the airco or the weather.com thing?
    Quote Originally Posted by Enforcer
    It won't.
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by WaterLift
    The climate at the moment just has the option of the weather screen. But as soon as some comes up with a way of interfacing to the climate controls, then we can look at skinning it in.
  6. #16
    Tainted Love Cris's Avatar
    Romania
    Again thanks m8
    Glad I could help.
    From what i've used so far (about all of them), the one that seems the most versatile would be Road Runner. It's also the most popular, there are many addons, skins available, and it has a great support.
    Centrafuse also promises to be a great front end. Version 1.6 will soon be released, and it has great expectations...
  7. #17
    FLAC sama's Avatar
    Feb 2006
    London, UK
    Kind of a late reply, but hey!
    Correction! The LinITX 8" Widescreen/CarTFT CTF800 does fit in the E39 dash. I've tried it and it goes in comfortably with a few mm to spare all round. I'll post measurements soon. I'm currently creating a bezel. It's my first attempt so it'll probalby be ****e!
    As for the frontend, you will probably use RoadRunner just because of this skin!
  8. #18
    Romania
  9. #19
    FLAC sama's Avatar
    Feb 2006
    London, UK
    just linking the threads, not repeating!
    Here's a link to screen fitting in the dash
  10. #20
    Feb 2006
    Belgium/Aalst
    Quote Originally Posted by sama
    Damn that looks sweet If I just waited 1 more day to order my CTF 7" I could have taken the 8" Any progress on the final bezel fitting?
  1. noob questions for custom carputer for BMW
    By jokgga in forum Newbie
    Last Post: 03-09-2006, 04:42 AM
  2. Start my own carpc build (have a few questions).
    By 1st time modder in forum Newbie
    Last Post: 01-10-2005, 07:11 PM
  3. Carputer SQ questions...
    By tweek in forum Newbie
    Last Post: 08-11-2004, 05:27 AM
  4. 3 Sound related questions for CarPC
    By nirvanades in forum General Hardware Discussion
    Last Post: 05-31-2004, 09:04 AM
  5. New to CarPC I have lots of questions
    By FreeFlyr in forum Newbie
    Last Post: 05-11-2004, 07:07 PM
