Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: BMW E39 carpc questions (Europe)
    Newbie WaterLift's Avatar
    Feb 2006
    Belgium/Aalst
    Question BMW E39 carpc questions (Europe)
    Hi everybody,
    I'm going to build me a carpc too but have some questions...
    Have a BMW 523i E39 early 1999 version with standard radio/tape+cd changer with DSP.
    I see a lot of nice hardware gizmo's but when trying to find out if it'd work I get confused coz of the multitude of answers and frontends. Some guys say it works perfectly and others are ******ing that it's worth ***** or that it's not supported, etc...
    What would I want to have in my Carpc all in 1 nice frontend:
    - radio RDS/TP (FM) maybe even DAB
    - mp3
    - Navigation GPS for EU with TMC and Radar information (+ max speed indicator)
    - Phone integration (Nokia 9500, already have BT carkit from nokia)
    - Ibus or whatever it is called to check the car diagnostics and fiddle with the controls
    - maintain the steering wheel controls
    - rearview camera (later on front view as well)
    - Video+TV (mpeg, divx, etc...) DVB would be nice
    - GPRS+WiFi browsing
    - VGA Touchscreen (8" if it would fit)
    - Access control (password or something)
    - Voice interaction
    - NES emulator for me (and maybe the kids )
    - Outlook calendar
    - Speedometer/rpm
    - rain/light/temp sensors
    - Additional gelpack battery (don't wanna drain my main battery)
    - iDrive kinda button to scroll thru menu's
    - SOS function (automatically dials emergency service nr with current position and identification of vehicle)
    - .... (I'm open to suggestions )
    Now the big question is what would work on 1 frontend and what do I need hardware wise.
    I have bought this little gizmo "Car2PC-BMW" http://www.indashpc.org/new/adapters/usbbmw.html so to have a clear audio signal without the need to buy a new amp/crossover/etc...
    Currently I have an ATX pc
    - P4 2.6
    - Asus P4P800-E Deluxe mobo
    - 1 Gig of memory (2x512MB)
    - 3.5" HD 80GB
    - USB BT dongle v1
    - PCI WiFi Belkin G
    - 2 x 5.25" CD/DVD drives
    - VGA Asus N6200 AGP
    Can I use anything of this pc or do I just sell it and buy an ITX/Pico carpc like the VoomPC (black edition) case with Epia mobo?
    The TFT I have in mind is an 8" widescreen but I'm not sure if I can fit it coz it is so close to the max height, I know there is someone who makes one hell of a nice bezel for the 7" liliput screens but it seems so empty with all that unused space The specs are here: http://www.cartft.com/catalog/il/550
    Can anyone verify if it would fit?
    Thanks & dudes your projects look awesome!
    WaterLift
    Here is my quote: '
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by WaterLift
    The truth is none of them really do work 100% perfectly, especially if you stuff them with all the aditional software you have in mind...
    - mp3
    - Voice interaction
    - Outlook calendar
    - Speedometer/rpm
    - rds and TA you can have only with a PCI FM card
    - well, that's obvious...
    - there are quite a few navigation programs that cam be succefully embeded into a front end, like Destinatot, IG, et. Depends on where you're from and what nav software you are going to use. Same thing for Radar feature.
    - I think all front ends support Phoco. Check for your phone's compatibility.
    - iBus is not for car diagnostics. For that you must have a OBD II scanner&software. iBus is for controlling stuff already in the car. Almost every BMW install has that.
    - Steering wheel control, you can have them though iBus
    - an AV camera is usually used for a rear view camera. So this is not something to be supported from a front end. However you can have an USB rear view cam, but it's not by far the idea solution.
    - video - obviuosly. TV - with a TV card. DVB, you can buy a separate kit, that pluggs into the AV from the monitor. It's a stand alone kit.
    - all front ends support browser. It depends on the skin though...
    - TS. 8" will not fit in that dash for sure.
    - access control. There's a little program by Stevieg that's made for Centrafuse.
    - Most front ends have voice interaction. But, if you want voince control that's a different matter...only in RR, this actually works.
    - most front ends have game emulators
    - not outlook, but you can have calendar in most front ends. Nut, since the net browser is already supported, you could use that.
    - Spedometer, depends on the skin. It reads it from the GPS.
    - RR has a section for sensors...
    - that has nothing to do with a fron end...
    - that's almost doable. It won't be the same...
    - I can't say I've heard about that...
    There's no front end that will satisfy all your demands by itself.
    - P4 2.6
    - 3.5" HD 80GB
    - USB BT dongle v1
    - PCI WiFi Belkin G
    You could use the RAM, HDD, WiFi, USB stuff...the rest they're a little too much for any PSU to take on. Not to mention all the stuff you want to add...
    As I said, as far as I know, an 8" will not fit in there.
    You can always add the buttons, but I'm sure it won't look as good as it does made by them.
    To sum it all up, I never told anyone to search, but I will tell you, because you clearly need to.
    Elsewhere
    You could use the PC itself, although I'd ditch the high-end 3D card. There's no need for that in a car at all and it will just suck up precious power.
    The only reason you wouldn't want to use that setup is simply size and power requirements. The power requirements can easily be handled by using an inverter (not recomended, at least by myself) or reading this FAQ and choosing an appropriate DC-DC PSU.
    How about the Wiki?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Cris
    It will work with any frontend.
    Actually doesn't even need a frontend.
    Romania
    Quote Originally Posted by Enforcer
    Really? I was it skinned specifically for CF...If it works, add it to your skin E.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It goes before your frontend.
    I currently use it.
    and hopefully will be adding to the features of it.
    in fact a patch has been released with the audio off facility.
    Romania
    I currently use it.
    Sweet. When do you reckon you'll be done with it?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    What do you mean 'done with it', these things are nevr 'done' they are always being tweaked and added to.
    anyway what do you want to see in it.
    Go answer that question in the correct thread, stop hijacking this one .
    Romania
    You're telling me? You're a hijacking thread specialist...
    I meant when will StevieG's access control be a part of your skin...
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    for now... but soon: http://www.xtronic.be/index.php?id=91&lang=2
  1. noob questions for custom carputer for BMW
    By jokgga in forum Newbie
    Last Post: 03-09-2006, 04:42 AM
  2. Start my own carpc build (have a few questions).
    By 1st time modder in forum Newbie
    Last Post: 01-10-2005, 07:11 PM
  3. Carputer SQ questions...
    By tweek in forum Newbie
    Last Post: 08-11-2004, 05:27 AM
  4. 3 Sound related questions for CarPC
    By nirvanades in forum General Hardware Discussion
    Last Post: 05-31-2004, 09:04 AM
  5. New to CarPC I have lots of questions
    By FreeFlyr in forum Newbie
    Last Post: 05-11-2004, 07:07 PM
