open your amp up and see if anything's come loose inside.
I wired a Punch 160.4 into my car and have the REM running off my Pioneer DEH-1550 Rem Accessories connection and have a seperate power cable to the B+ on the amp as well as a good earth but the only way i can get the amp to power up is if the REM connnector is bent down & touching the external metal case of the amp. I know its wired correctly. Can anyone tell me if this is safe or if it means i have a lose connection inside the amp.
Never mind found the problem but thanks anyway. Turned out the cb was double sided and i had re soldered one side but not the other.
