Results 1 to 8 of 8
Thread: Carputer for 2005 Nissan Altima
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    Hello everyone.
    I am new to this carputer stuff, but I am very excited about starting this project.
    I just bought a new 2005 Nissan Altima. After doing lots of research on the forum, I decided to go with this setup. I wanted to get your opinion and maybe some recommendation on these parts that I want to buy before I make any mistakes. For the computer I decided to go with the mini ITX and for the monitor I want to get the Lilliput 7" VGA Touchscreen. Here is a brief list of the hardware I am planning on buying:
    - C134 Mini-ITX Case Black $140.00 (I wanted to go with the Morex Cubid 3688 Mini ITX case but it is not standard DIN, and since I wanted to mount the computer on the dashboard for easy access to usb ports and drive bay, I decided to get the C134)
    - Lilliput 7" VGA Touchscreen 619GL-70NP $254
    - VIA EPIA SP13000 Mini-ITX Motherboard $225
    -Pioneer Slot Load DVR-K05 DVD±R/+R DL/±RW Dual Drive 8X $145.00
    -2.5" Hard Drive 80GB Samsung 5400rpm $240
    - Ultra Low Profile 512MB DDR PC3200 RAM $148.99
    - Audigy 2 NX external USB sound
    - Power Supply ( Don't know yet - Which should I get for this set up? )
    - AMPLIFIER ( Don't know yet. Any recommendation would be appreciated)
    - Speakers + Sub ( Haven't decided yet, also here any input would be appreciated)
    - GPS ( Don't know which one to get yet)
    - WIFI
    - Keyboard and mouse (wireless preferable)
    I think that's it, hope I did not forget anything too important.
    This is what the dashboard for the 2005 Nissan Altima looks like:
    I am thinking of mounting the monitor right where the small compartment is
    and the computer wight below it where the LCD discplay is. I will probably have to take it to a shop to have it mounted since I am not very handy when it comes to these type of work and I do not have the tools. I have built many PCs myself ( desktop ), so I should not have problems with the PC set up and the wiring.
    I have a budget of 1500.00 for the whole project, I don't want to spend more than that. I plan to finish it in probably 2 months if everything goes as planned.
    If anybody is familiar with a good shop where I can have the monitor mounted, that would be great, I live in MD.
    Thank You.
    2005 Nissan Altima - Completed 2007
    2010 Nissan Altima - Coming Soon...
    FLAC alti's Avatar
    NY
    take a look through the projects threads there are a number of 02-04 nd 05-06 altimas with screens mounted where you are considering (above the radio) One of the mods of the forums (altimat) had done a while back and sold them for the 02-04's
    good luck on your project. Personally i would use differnt hardware, but i also was not looking to install my computer in the dash. You should be able to complete the project for around your budget.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    Feb 2006
    Columbia/MD
    So I changed my mind, and did a lil more research,
    I am not going to install the computer on the dashboard,
    but below the passenger seat.
    This is my first diagram as to how I am going to do it.
    Please feel free to give me any feedback or recommendation.
    Some of the hardware parts I want to get, I have identified;
    the others, i am not decided yet.
    Here is what the wiring and placement would look like, looks like I will need long cables and wires.
    The hardest part for me would be to mount the LCD on the dashboard,
    since I do not know how and do not have the tool, I have decided to
    buy the dashboard frame from the 05 altima that has a navigation system,
    I can then use the cutout of the LCD to place my own xenarc LCD. Hopefully
    it will fit.
    my car
    Tainted Love Cris's Avatar
    Romania
    Look at Altimat's installs.
    Feb 2006
    Columbia/MD
    Here I go again. Well I changed my mind on a couple of things.
    1- The monitor will not be located on top where the small compartment is, I will mount it where the radio is see 2005 Nissan Altima
    2- I have decided to go with a destop PC, a MicroATX case and motherboard
    For the case http://www.tweaknews.net/reviews/a106/index2.php
    http://www.newegg.com/Product/Produc...190-018&depa=0
    http://www.xpcgear.com/lib/extremepc...se-03-256k.wmv
    I wish the LCD display was horizontal so I can place in the dashboard.
    with a 2.8 Ghz Intel Pentium 4 processor. I have not decided about the motherboard yet, but most likely will be an ASUS microATX.
    -A desktop 3.5'' Hard drive instead of a 2.5''HDD
    -150W opus power supply
    -The monitor will be power by the OPUS.
    Feb 2006
    Columbia/MD
    After 1 month of planning, I came up with this. I am about to purchase the parts next week.
    My concerns so far?
    Will I have enough power on the M2-ATX to power my peripherals?
    Do I need a second battery because of the inverter I am using ( although I will not go pass 200W on the speakers)
    I will first test everything on my bench and measure all voltage rail power to make sure everything is working fine.
    Then I will take everything to the car and install the inverter and the PC, then measure the power on the inverter when I am listening to music and see how high is enough.
    That's about it.
    Please comment...
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    why go with a 64 sempron when NOTHING you'll run inside the car is 64 bit? i have a 2800+ mobile athlon with just about every peripheral one could think of installed on a m2-atx, but i'm not sure the 64 sempron will allow it.
    Live mp3Car Facebook Chat
    Feb 2006
    Columbia/MD
    Quote Originally Posted by Sonicxtacy02
    Thank You, will consider that...
  1. 98 Nissan Altima OBD II? to carputer???
    By tsparks in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-30-2006, 10:09 AM
  2. Nissan Altima
    By Evilbunny1114 in forum Newbie
    Last Post: 01-28-2006, 12:32 AM
  3. 1998 Altima Carputer project
    By silveralt in forum General Hardware Discussion
    Last Post: 12-25-2005, 03:23 PM
  4. FS: 2003 Nissan Altima w/ Carputer - LOW MILES
    By KingsDude in forum Classified Archive
    Last Post: 12-18-2005, 03:31 AM
  5. Carputer in Nissan Primera
    By Primera in forum Newbie
    Last Post: 04-21-2004, 02:50 PM
