Results 1 to 2 of 2
Thread: POL overloaded USB hub?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    so I've had the carnetix POL hooked up for some time now......havent used this hub in forever though.....anway.........it gets really hot....noticed today my PC doenst recognize it.....but it once did.........the voltage reads a steady 5.09V......but at 3+ amps......did i fry this thing.....or would it only pull what it needs?......also....the bluetooth adapter hooked up to it....seems to be dead too......has anybody had any issues with the POL?
    PC Components:
    My work log
    Dec 2004
    Maryland
    ......i found part of issue. I noticed that the thing does not shut off....found that my signal wire came unsoldered (pulled it to hard)........so the thing is always on now.......
    what good is having a signal wire.....it it turns on without it?
    PC Components:
    My work log
  1. Replies: 2
    Last Post: 09-26-2005, 09:59 AM
  2. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 11:44 AM
  3. Powering external USB HUB
    By Montanaja in forum Power Supplies
    Last Post: 09-21-2005, 11:57 PM
  4. Power USB hub from psu
    By meyer64 in forum Power Supplies
    Last Post: 03-20-2005, 10:34 PM
  5. USB HUB problems????
    By chuckctv in forum Input Devices
    Last Post: 10-08-2004, 11:38 AM
