Results 1 to 5 of 5
Thread: dsatx help!
    Jan 2006
    dsatx help!
    Hello, im currently planning out my carputer and have started buying items for it. i am at the critical point, which psu to get? i decided on the dsatx because i plan on powering my machine, its various accessories and the screen. my question is this though, i will be using a mobo from a dell optiplex gx260 and here is the link for a pik of it with its connections
    http://support.dell.com/support/edoc...rd.htm#1100517
    i was wondering where would i plug in the simulated "power on" connection from the dsatx into it. the power button on this case is connected to a board which is connected to the mobo. can someone please help me how to connect the psu into this mobo, thanks
    Sep 2005
    The dsatx has a power on header for simulating a push of a button. This is usually triggered by the acc hookup. I just hooked mine up today (dsatx, not dell mobo) and it works fine. zootjeff will probably be along to describe it in detail, but you get the gist.
    Aug 2005
    How/where are you guys planning on mounting your DSATX? I've been keeping an eye out for a nice little prefab case I can mount it in, but I haven't had much luck yet.
    In the works...
    Dell GX240 SFF
    P4 1.8GHz, 256 RAM, 160GB HDD
    8" Lilliput (fab work completed - F-150)
    My worklog
    Misc crap FS - OLD laptop (w/ adapters) | Sony memory | USB key | Printer Dock, etc
    Elsewhere
    Mine's going inside my case, most likely.
    How about the Wiki?
    Sep 2005
    I mounted mine inside my pc case. Fits quite nicely.
  1. DSATX Power Supply on LV-673 MoBo
    By Caelric in forum Power Supplies
    Last Post: 12-17-2007, 04:21 PM
  2. DSATX and PCI Sound
    By speedjunkie in forum Power Supplies
    Last Post: 01-24-2007, 04:45 PM
  3. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 09:47 PM
  4. dsatx issue
    By gameboy in forum Power Supplies
    Last Post: 02-25-2006, 05:12 PM
  5. DSATX not powering up
    By alti in forum Power Supplies
    Last Post: 10-30-2005, 12:37 PM
