Results 1 to 10 of 10
Thread: mounting case inside car
    Mar 2006
    Ann Arbor, MI
    if this has been asked before a link or more search terms other than "case" or "mount" would be helpful.
    So how exactly are people mounting cases in their cars so they don't slide around when they slam on the brakes or something? I've seen the VoomPC case has screw holes, but what do most people do?
    I've seen projects where its stuffed into the glove compartment (ugly) as well as people modding the interior of the car to fit a case. However, I'm not really looking to modify the interior too much. (I'm not an expert at this type of stuff nor do I wish to spend the time/cash to do anything too drastic.)
    I noticed the Travela cases claim to be able to fit into a DIN or double DIN, but do they come with "mounts" (or whatever the term is) to hold them in place? The pictures that I've seen would make it appear otherwise.
    Thanks!
    Low Bitrate silveralt's Avatar
    Dec 2005
    Some people mount them to the floor or wall of their trunk. Other people mount them to their subwoofer box. I have no idea why they mount it to their sub. I don't think it would be too safe for the pc with all the vibrating. If I had a pc to mount in my car, I'd go for the mount on the side of the trunk or behind the dash. I am doing a laptop install in my car, though. Here is an example of a total in dash install.
    http://mp3car.com/vbulletin/showthread.php?t=62063
    Hope this helps!
    Tainted Love Cris's Avatar
    Romania
    Those little Travlas don't usually fit flush, as they're a bit too long so it would probably stick out of your dash a little.
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by Cris
    i made that mistake early on, and wasted money on a case i couldn't use.
    Sep 2005
    I am using some angle brackets and zip ties. It's a slim pc case, and the brackets hold the case from going anywhere, and the zip ties are there to keep things from moving in extreme stop situations.
    Mar 2006
    Ann Arbor, MI
    thanks for the tips!
    Low Bitrate LVExpo's Avatar
    Oct 2005
    Las Vegas
    velcro
    u can also use velcro strips. i heard it works fine, but i wanna try this first!
    Elsewhere
    Since mine is going to be under the seat, mounted with other components, I'm going to cut a piece of MDF to fit, and use a router (think wooodworking here, ya damn geeks!) to cut a recessed well for the Shuttle case to fit into. Figure a 1/4" well shouldn't be to difficult on a 1/2" piece of MDF.
    How about the Wiki?
    Mar 2006
    Ann Arbor, MI
    Mdf?
    Also, does anyone know why the forum keeps lowercasing the 'd' and 'f' when I type all 3 letters in uppercase, or how to fix this?
    Oct 2004
    MDF = Medium Density Fibreboard
    Kinda like plywood, except it's pressed/glued wood fibers
    http://www.design-technology.org/mdf.htm
    If your entire post is in caps it'll change the case. If you make a post with something in caps and include some lower case letters somewhere it'll leave the CAPS in CAPS. Anti-AOL-shouting technology, I suppose.
  1. Replies: 19
    Last Post: 10-27-2005, 12:53 AM
  2. Painting Ampie Case
    By semovodka in forum General MP3Car Discussion
    Last Post: 10-08-2005, 05:37 PM
  3. Question about Car PC case.
    By DomesticImport in forum General Hardware Discussion
    Last Post: 02-15-2005, 06:17 PM
  4. My new car, pic inside
    By lstrunk in forum Off Topic
    Last Post: 07-13-2002, 10:59 AM
  5. Mounting the case
    By TheFly in forum General Hardware Discussion
    Last Post: 05-05-2002, 04:11 PM
