Results 1 to 10 of 13
Thread: head units and car pcs
    Mar 2006
    Ann Arbor, MI
    When you put a pc in your car with optical drive, is there still a need for a head unit? I believe I've seen them included in some of the projects I've looked at, but it seems to be as long as you can hook the pc up to the sound system and it has an optical drive, a head unit wouldn't be needed.
    Newbie malreynolds's Avatar
    Mar 2006
    Toowoomba, Australia
    From what i've managed to pick up, it depends on a few things. Personal aesthetics can be one, but on a more practical level it's good for using the radio in-car (much more difficult in most instances to have an FM tuner inside your PC) and also for people who hook their PC sound to the car through an FM transmitter.
    As to specifically have a CD one, i'm not sure. I'm personally wondering if I'll end up ditching my pioneer mp3 after a carputer install and go for a good simple radio.
    There may be better reasons than mine though
    You can't take the sky from me...
    Carputer Progress:
    [|----------] (I have the car...)
    Low Bitrate silveralt's Avatar
    Dec 2005
    Well. I am going with a head unit just incase the pc crashes. Or if you're not going to be in the car long enough to feel like taking the time to boot the pc.
    Elsewhere
    That depends of your vision for your project, really.
    Can you go without a headunit entirely? Yes, you can. You're going to lose AM radio and likely FM radio by going without a headunit, however.
    Ultimately I will be headunit-less.
    How about the Wiki?
    FLAC -zip-'s Avatar
    Ontario/Canada
    It is not a must, allows you to do more things and have a backup. Thing is, you will not use it very often.
    Sound Stage
    Eclipse|MTX|Infinity
    Mar 2006
    Ann Arbor, MI
    will you necessarily lose fm radio though? would there be anything preventing me from getting fm radio through a cheap TV tuner with fm radio support?
    Constant Bitrate randomjohn's Avatar
    Sep 2005
    CT
    Quote Originally Posted by johnnm
    Only if you care about reception, which generally sucks with the currently available tuners. If you're in an area where there's ridiculously good coverage, or you don't listen to much FM (and no AM) then you're probably ok.
    GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
    Worklog: http://www.mp3car.com/vbulletin/worklogs/65059-03-jetta-if-i-can-any-idiot-can.html
    Now with pictures!
    Jan 2006
    Michigan
    Im removing my head unit also. using a old wintvusb adapter I had laying around from a couple of years ago, which will connect to the car areal for FM and possible TV.
    Mar 2006
    Ann Arbor, MI
    Quote Originally Posted by randomjohn
    So is there no way to connect the TV tuner to the car's antenna to improve the reception to match the quality to that of a head unit?
    Jan 2006
    Michigan
    Im hoping there is a way. I'll let you know if I figure it out.
    The stock head unit had 2 plugs going into it. a 2 wire one and a 20 pin one with 13 wires in it.
    I had assumed the 2 wire one was power, but it may be the areal. i'll have ot check up on this.
  1. Article: ParkingEye camera notifies metermaids
    By VanMan69 in forum General MP3Car Discussion
    Last Post: 04-28-2005, 05:09 AM
  2. XM-Ready head unit software integration?
    By TaZMaNiaK in forum Software & Software Development
    Last Post: 04-02-2005, 06:23 PM
  3. New Sony head unit - botched wiring...
    By SamDude in forum Car Audio
    Last Post: 09-09-2004, 05:21 PM
  4. Decent Head Units
    By chewiee in forum Car Audio
    Last Post: 04-16-2004, 09:06 AM
  5. Cheap head units ok? Which ones?
    By ncfoster in forum General Hardware Discussion
    Last Post: 12-19-1999, 10:27 PM
