Results 1 to 10 of 12
Thread: Newb SPDIF Question
    Jan 2006
    Michigan
    Newb SPDIF Question
    My VIA SP13000 board for my carpc has spdif so can I run one cable from my amp if it has spdif to the pc ? does it carry all 4 channels for all 4 speakers or just l/r stereo ?
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    If you have a SPIDF-in on your amp than YES, all you have to run is that digital coaxial spidf cable from your pc to your amp. It will have all 5.1 channels and you will probably only be using 4 or 4.1.
    I am running a digital coaxial cable from my epia M10000 to a coaxial/optical converter to my Alpine Digital Sound Processor (has optical input) which has rca-outs that go to my amps.
    Digital is much better and you will have a noiseless set-up. If you have an amp with SPIDF-in, than you're in luck. Most amps with spidf inputs require a specific head unit to be able to select the source, but there are some out there that are stand alone amps.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I'm also running the SP13000 via spdif into my DSP then into my amps.
    Digital can carry more than 2 channels.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    Jan 2006
    Michigan
    cool , thanks
    Thanks for the info. I love this site and forums !
    FYI: My install is....
    sp13000 mb / 512mb ram , 120gh wd hard drive
    Travla C158A-M1DC Black case
    Bluetooth / wifi / Hauppage wintv USB for fm radio.
    Extra Video card for second display for dedicated movie watching by kids.
    The Vehicle is a brand New 2006 Honda Odyssey LX
    (odyessey van sa a new under floor compartment behind first row of seats which is ideal for the pc. (I'll install a fan in it for ventillation)
    I'll be documenting it and photographing it and putting up a page in a few weeks I hope.
    My Wife is fabricating a new pannel for the 8inch in dash lilliput touch screen.
    Jan 2002
    Long Island, NY
    Quote Originally Posted by kiwiruss
    sp13000 mb / 5112mb ram , 120gh wd hard drive
    Wow, thats alot of ram for a van.
    Jan 2006
    Michigan
    Yeah too much. A type im afraid :-(
    Jan 2002
    Long Island, NY
    What speed ram? 400DDR?
    Jan 2005
    Quote Originally Posted by 3onDubs
    Just to hijack a bit... could i use a digital amp instead (amp with digital inputs) like the Alpine MRA-D550 or MRA-F350... i've heard it may not work because of some AI-NET (i don't even know what the heck this is..) issue...
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    Check and make sure that the amp can decode multichannel audio. Just because it will accept a digital input doesn't necessarily mean that it will decode multichannel (e.g., surround) audio.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Feb 2006
    I believe the issue is that Alpine amps need an Ai-Net connection to control them. I am not sure on this.
    Ai-Net is the analog control cable bundle that alpines use. It allows the HU to control the amps or CD changer or signal processor if they are also alpine.
  1. Newbie question
    By jaydm in forum General Hardware Discussion
    Last Post: 10-21-2006, 11:07 AM
  2. Enable SPDIF on EPIA M10000
    By titaniumkingpin in forum General Hardware Discussion
    Last Post: 02-28-2005, 05:07 PM
  3. NEWB Question about on/off switch
    By mazda3uzr in forum Power Supplies
    Last Post: 02-03-2005, 09:57 PM
  4. Newb question on PS's
    By edrex in forum Power Supplies
    Last Post: 12-10-2004, 03:53 PM
  5. newb grounding question...
    By bstanton in forum General Hardware Discussion
    Last Post: 01-15-2003, 02:02 PM
