Results 1 to 4 of 4
Thread: sat nav
    Mar 2006
    sat nav
    hi there im a new member but i have been on this site quite a lot, im wondering about about getting an all-in-one system which has sat nav, pc and sterio, i was wondering how sat nav works and how i can link a system like that up, are there any good devices which are all in ones and whats kind of cost am i looking at ive got about $2000-$2500 to spend but the cheaper the better aslong as the quality is ok
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    <looks around for flame retardant suit>
    That is essentially the point of the car pc....
    You have found the right place to answer all of those questions. Good luck in your SEARCH for answers.
    All (okay most) of us here are on the same quest and have spent MANY hours with SPOONful after SPOONful of reading to come to the conclusions that have FED to the success of these forums.
    Your best bet is to start with the basic idea of getting a PC that will work best for your needs and start from there.
    2000 or more should be plenty of money to build a system, unless you consider the time to SEARCH all these threads. It does take time, but you will be happier if you do it from SCRATCH. MY suggestion, HEAD over to the newbie area and read the FAQs. That will get you started in the right direction.
    Good Luck and don't forget, Specific questions are easier to answer....
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
    Low Bitrate pancakeboy's Avatar
    Mar 2006
    Toledo
    Post
    I personally haven't tried this, but if you want an all in one solution without fiddling with anything, then try this:http://www.mp3car.com/store/index.php?cPath=51. It also has it's own forum. Check it out. Also search the forums a bit more. Most question have been asked before.
    Elsewhere
    How about the Wiki?
  1. StreetDeck Functions
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 01-15-2008, 11:44 PM
  2. Carful with your Sat Nav and In Car Computers
    By itrends in forum General MP3Car Discussion
    Last Post: 12-21-2005, 09:45 PM
  3. bmw/mini sat nav
    By mutilator in forum Car Audio
    Last Post: 08-07-2005, 09:43 PM
  4. Replies: 3
    Last Post: 08-07-2005, 11:41 AM
  5. Replies: 3
    Last Post: 03-27-2005, 07:23 AM
