Results 1 to 9 of 9
Thread: pc wont power off with m2atx
    Mar 2006
    LEEDS UK
    Hi folks, i have been floating around the site for a while gaining lots of usefull information, unfortunately i only found the site after i had done all of the trial and error stuff on my own. thanks to you guys i could ditch the inverter regular power supply and the complicated auto power on stuff! sooo i purchased a m2atx power supply for my car pc thats in my glovebox:
    duron 700mhz
    512mb ram
    80gb hard disk
    unknown motherboard
    m2atx
    windows xp
    anyways my problem is as follows:
    the m2atx power supply switches the computer on fine, as does the secondry push button which i wired in to it. my only problem is that neither the m2atx or the bush button will initiate windows shutdown, i have been into the power management in windows, enabled the apm and selected the "shutdown computer when power button is pressed"
    also i have been into the bios but cant find anything that relates to the power button.
    so i assume that the computer should shut down with the press of the button, but it doesnt! i have to hold down the button for 5secs instead!
    any ideas anybody? everything else is working ok except for this!
    any help would be much appreciated!
    oh and sorry for the long post!
    Mar 2006
    check your jumpers and line that connects psu to mobo. you might have the wire on the wrong pins
    Mar 2006
    LEEDS UK
    i have checked, the pc starts fine with the power supply so the connection is not the problem, it must be something to do with windows not noticing that the power button has been pressed.
    Low Bitrate NoTicketsPlease's Avatar
    Jan 2006
    San Diego, CA
    Windows XP is ****!!!
    AMD Sempron 3000+, ASRockVM800, 256MB, 250GB 3.5", DVDRW+, WIFIg, m2-atx, Lilliput 8", RR, GoogleEarth
    Need: daylight viewable screen!
    Mar 2006
    LEEDS UK
    thank you so much! you are a star! will try it tomorrow.
    and before anybody mentions anything about searching for the answer id did but the search filters out the usefull words
    thanks again!
    Jan 2006
    San Diego, CA
    Quote Originally Posted by jammy-dodger
    thanks again!
    no problem. I seached and posted too but could not get an answer. I then stumbled on the solution. This should be in the power supply faq, an m2-atx faq would be nice too.
    I heard about jammy dodgers from eddie izzard, dont think we have them here in the states though
    Mar 2006
    LEEDS UK
    no you dont have jammy dodgers, theyre ok but not great, it was just a nickname at school. anyways bad news! firstly, how do i know if i am using minlogon? secondly the fix isnt working because i dont have the option to put the computer into standby!!!! all i have to chose from on the power button menu is:
    do nothing
    ask me
    hibernate
    shutdown
    this poses a problem as the fix relies on you selecting the stand by option which i dont have. concequently the computer is still no shutting itself down.
    can i disable minlogon if it is the main problem of all this?
    Mar 2006
    LEEDS UK
    right folks after much research i have found the answer! when i installed windows originally all apm features on the bios were disabled, so windows installed onto what it thought was a dumb machine, unfortunately it appears that even turning on the apm in the bios it does not help, windows has to be re-installed which is a bit of a ball ache to say the least! i will have to install it in the car as i now only have a m2atx supply grrrrrrrrrrrrrr !
    anyways i hope this helps future people who also forgot to enable the apm in the bios!
    Jan 2006
    San Diego, CA
    minlogon is something you would have installed by hand. so if you dont know you have it, you probably dont have it. One other thing I tried was a bios update. Search google for "xp shutdown troubleshooting" or similar, there are a few pages on it.
  1. Powering PC With Power Button Instead of Automatic Power
    By legend5761 in forum Power Supplies
    Last Post: 04-17-2008, 11:41 AM
  2. FS: CarPC 2.4 startup/shutdown controller
    By evilragu in forum Classified Archive
    Last Post: 03-05-2006, 05:28 PM
  3. Replies: 8
    Last Post: 08-23-2005, 12:43 AM
  4. Alternative ways to power up pc from cold
    By kungmpton in forum Power Supplies
    Last Post: 05-07-2005, 01:23 AM
  5. Replies: 5
    Last Post: 06-16-2004, 01:41 PM
